| a390 info https://slantsix.org/forum/viewtopic.php?t=54815 |
| Author: | martin53 [ Mon Mar 10, 2014 6:48 am ] |
| Post subject: | a390 info |
Can someone please help me with some info on the a390. Its originally a column shifted but looking to make it a floor shifter. I was looking for info on where 1,2,3,and reverse are I can move the first shifter lever on the tranny but the rear lever won't budge is this normal I'm hoping the reverse isn't locked up or the tranny is trashed. |
| Author: | DusterIdiot [ Mon Mar 10, 2014 7:14 am ] |
| Post subject: | Typically... |
Typically one lever or the other has to be in the middle position or neutral for the other lever to engage a gear...so if the front lever is in the middle then your should be able to mover the rear lever...if you had a driveline yoke to install in the tailshaft you can rotate the assembly a little to see if it frees up the other gear and allows it to shift. |
| Author: | martin53 [ Mon Mar 10, 2014 7:44 am ] |
Thanks duster I'll try this when I get home |
| Author: | bob fisher [ Tue Mar 11, 2014 5:38 am ] |
| Post subject: | DI knows his trans |
Hi DI- didnt the first dusters in 70 have the 390 manual 3 speed with either column or floor optioned factory shifters. i think the floor shifter for the 390 was the inland not hurst model. later the 230 full synchro 3 speed became an option and had a floorshift or column option too. am i right? paladin |
| Author: | martin53 [ Tue Apr 01, 2014 11:35 am ] |
well that worked. I'm trying to make shifte linkage but which lever is what I was thinking the rear is 1 and reverse but not sure there is no information on these transmissions anywhere. Can anyone help me with this |
