weber 32/36 for a blowthrough
https://slantsix.org/forum/viewtopic.php?t=54856
Page 1 of 1
Author:  /6rampage [ Fri Mar 14, 2014 9:19 am ]
Post subject:  weber 32/36 for a blowthrough
Has anyone setup a Weber 32/36 for a blow through set up? An how can it be done?
Author:  Joshie225 [ Fri Mar 14, 2014 10:03 am ]
The 32/36 is fine for a stock engine, but that's it. 1600cc VW Rabbit racers want more flow than the 32/36. You can't get enough fuel through the needle and seat assembly to support a boosted engine. The air speed through the carb will get so high that the internal passages won't flow enough fuel even if you do make a needle and seat that will keep the float bowl full. Maybe with a pair of Weber 32/36 carbs you could get close, but a single 4bbl is going to be easier.
Author:  Serj22 [ Thu Jul 24, 2014 5:41 am ]
Ford pinto owners use them a lot for turbo and the 38/38 has blow through parts available online. Unfortunately no one I've seen has documented what they did with the weber to convert. There's also a couple companies that sell a modified new weber to be used for turbo on older Mitsubishi trucks.
In other words it can be done but I can't point you to anyone that explains how. Also most of them are mounted to 2 litre motors or smaller.
