| Holley 1920 arrived today https://slantsix.org/forum/viewtopic.php?t=54861 |
Page 1 of 3 |
| Author: | Sean Mallory [ Fri Mar 14, 2014 4:20 pm ] |
| Post subject: | Holley 1920 arrived today |
code is 7587, not 7586 as depicted on our beloved internet and the throttle shaft has slop, brand is Vapex two questions is this the Economaster I want? how much slop is acceptable in the throttle shaft? I never get an answer my Holley EFI on my Jeep has ZERO play |
| Author: | Sean Mallory [ Fri Mar 14, 2014 4:46 pm ] |
Well I was angry because the number didn't match. I went and measured and the slop is 2-3 hundreths of an inch. Enough to move the shaft back and forth laterally and see a gap. Same gap on both sides. Now I'm a bit calmer. SSDan says 7587 is '73 Economaster. Researching the slop tolerance on the net now and not coming up with much. |
| Author: | Aggressive Ted [ Sun Mar 16, 2014 2:09 pm ] |
Sean, You can tell an Economaster in a millisecond, by looking down the throat..... Does it have a wagon wheel venturi? or does it look like a Hamm radio antenna? Mine part number is 7585..... On the shaft......mine had a fair amount of slop even when it was brand new! Don't worry about it.....it idles perfectly at 2 turns out and the engine pull 19" of vacuum at idle, never missing a beat at 600 rpm in gear for hours in traffic. You can check the pictures and numbers on mine by clicking on the red link below. |
| Author: | Aggressive Ted [ Sun Mar 16, 2014 6:53 pm ] |
Sean, I use the EGR port for alcohol/water injection. I like it better than the EGR for knocking back the timing. Besides it keeps the engine clean and idle crisp! Yes the gaskets are very different. In fact, I use the super thick (almost a half inch thick) Fel-Pro gasket under mine. That helps reduce heat soak as does the heat deflector and electric fans. It all goes along way to stop loosing all the gasses during normal heat soak and for quick hot restarts. I have heard cars crank and crank and crank trying to make a hot restart. Mine will fire off and start immediately. |
| Author: | Sean Mallory [ Mon Mar 17, 2014 6:45 am ] |
Do you have that Felpro PN? or a way I can look it up I think I found it, FelPro 60125 |
| Author: | 6inarow-makemego [ Mon Mar 17, 2014 5:07 pm ] |
Where did you find it? I'm also looking to pick up an economaster carb. What did you pay for it? |
| Author: | Sean Mallory [ Tue Mar 18, 2014 7:00 am ] |
Quote: Where did you find it? I'm also looking to pick up an economaster carb. What did you pay for it?
last one...http://www.ebay.com/itm/331143510907?it ... m=&vxp=mtr |
| Author: | 6inarow-makemego [ Tue Mar 18, 2014 9:14 am ] |
Thanks...a little pricey for me. I'm hoping to find a used one to rebuild myself. |
| Author: | 6inarow-makemego [ Tue Mar 18, 2014 7:01 pm ] |
Believe me, I've been there and done that. The love of a truck has convinced me to pay top dollar for a 1bbl carb in the past…. ![]() |
| Author: | Sean Mallory [ Wed Mar 19, 2014 6:48 am ] |
Awesome ride! what is it? |
| Author: | 6inarow-makemego [ Wed Mar 19, 2014 6:59 am ] |
Thanks, it is a 1957 Dodge D-100 with flathead 6. |
| Author: | 1930 [ Wed Mar 19, 2014 4:47 pm ] |
I love both trucks, one looks very clean and original/un-restored and the other looks like a very clean restoration. |
| Author: | Sean Mallory [ Wed Mar 19, 2014 5:35 pm ] |
Mopar forever. |
| Page 1 of 3 | All times are UTC-07:00 |
