| aluminum drive shaft https://slantsix.org/forum/viewtopic.php?t=54876 |
| Author: | DadTruck [ Sat Mar 15, 2014 1:42 pm ] |
| Post subject: | aluminum drive shaft |
at the pull a part, noticed a couple of Dakodas with aluminum drive shafts, would one of those be a suitable donor to the 68 Barracuda when I do the swap over to a 8.75 rear and a 833 tranny? figured if I need to modify the drive shaft for length,, should use a modern light weight part,, is that a good plan? thanks. |
| Author: | Dart270 [ Sat Mar 15, 2014 3:16 pm ] |
I bet the Daks are shorter, but not a bad idea, no... I have had Denny's Driveshaft in NJ make me an alum driveshaft from scratch. Lou |
| Author: | dartsport76 [ Sat Mar 15, 2014 7:10 pm ] |
| Post subject: | dont mean to hijack... |
But can a driveshaft shop shorten a composite (carbon fiber?) driveshaft? Cause I've got one thats longer... |
| Author: | Dart270 [ Sat Mar 15, 2014 8:57 pm ] |
Carbon fiber - highly doubtful. Aluminum, some shops but not all. Lou |
| Author: | GTS225 [ Sun Mar 16, 2014 6:13 am ] |
I seem to remember seeing ally shafts under Ford minivans. (I am gettin' old, though.) Roger |
| Author: | Reed [ Sun Mar 16, 2014 7:55 am ] |
My 89 Ford E 150 full size van has a factory aluminum driveshaft. |
| Author: | Kidd [ Sun Mar 16, 2014 6:34 pm ] |
Was told to find a aluminum driveshaft from the ford version of the cop cars....that the sized universals would convert them....but dont remember about the length. |
