| Coolant Pump Question https://slantsix.org/forum/viewtopic.php?t=54937 |
| Author: | RyGuyTooDry [ Sun Mar 23, 2014 9:54 am ] |
| Post subject: | Coolant Pump Question |
Anyone know how to take apart a coolant pump? The flex plate on mine is pretty rusty so I wanted to clean it up and clean the corosion on the inside of the housing. I can't figure out how to get it apart... Thanks! |
| Author: | Joshie225 [ Sun Mar 23, 2014 11:01 am ] |
If you mean the engine mounted water pump it takes a press to assemble and disassemble. |
| Author: | RyGuyTooDry [ Sun Mar 23, 2014 12:04 pm ] |
Yes, that's the pump I'm referring to. Do you know which way it presses out? |
| Author: | Joshie225 [ Sun Mar 23, 2014 2:30 pm ] |
Leave it alone or replace the assembly. You'll only make yourself miserable attempting to disassemble the water pump. |
