| Dyno Results *Graph and Sheet Added* https://slantsix.org/forum/viewtopic.php?t=54944 |
Page 1 of 2 |
| Author: | 1974duster kev [ Sun Mar 23, 2014 8:43 pm ] |
I would say more cam and compression should reach that goal pretty easily along with the 4bbl Kev |
| Author: | Dan-o [ Sun Mar 23, 2014 9:15 pm ] |
I have a shaved head that is ported and valved the same as this one. However, we had to run 100 just to drive it around town and 110 at events. Wife says no more race gas, lol. We have it on the pump here, but 8 bucks a gallon gets a bit nuts. |
| Author: | Joshie225 [ Sun Mar 23, 2014 9:50 pm ] |
50 ft/lbs is a 28.5% torque increase. I don't see that happening without forced induction. You can get the horsepower up where you want, but it's going to take more cam, carb and compression. |
| Author: | Dan-o [ Sun Mar 23, 2014 10:22 pm ] |
You think the head is so restrictive we can't get 1ft/lb rwtq per cubic inch? I was reading the "build matrix thread" and I've deemed it pretty subjective. I find it hard to believe no one has hard dyno numbers for their cars... |
| Author: | slantzilla [ Sun Mar 23, 2014 11:20 pm ] |
You have not put the 4bbl on yet, correct? When I changed my Duster from a Super Six BBD to an Offy and 390 Holley it picked up over 1/2 second. A BBD is an improvment over a 1bbl, but it is still a cork in the sytem, especially with a ported head and big valves. Also, if you are on a chassis dyno your numbers are already 15-18% lower than an engine dyno. |
| Author: | classic ap6 [ Mon Mar 24, 2014 4:55 am ] |
Dan-o I'm definitely interested to see how your upgrade to a 4bbl works out. I'm running a similar setup to you and I recently got 138 rwhp and 160 rwtorque. I think I can get more out of it the timing wasn't right and I had overheating issues so had to shut down prematurely I'm currently running a 2bbl 500 holley but would like to see what a 600 4bbl would do. Love to see your dyno graph Good luck with it PS what was your AFR reading? Cheers |
| Author: | 1974duster kev [ Mon Mar 24, 2014 6:18 am ] |
If you had more cam it would lower your dynamic compression which would allow you to run lower octane fuel. My previous NA motor used an erson cam 238@.50 duration 108lsa 510 lift with slightly over 10:1 compression ran on pump gas everyday as a daily driver. Your 264 comp cam is a pretty mild cam which would cause you to run into those ping problems when raising the compression. Kev |
| Author: | Joshie225 [ Mon Mar 24, 2014 6:37 am ] |
Quote: You think the head is so restrictive we can't get 1ft/lb rwtq per cubic inch?
Dyno testing costs money and isn't available in a lot of places. More of us go to the drag strip. I can't tell you what the horsepower and torque changes were, but I improved my '67 Valiant from a best of 19.2 to a 16.9 in the 1/4 mile with head, intake and exhaust work. No cam change, no bottom end work. Real numbers, but not the one's you're looking for. I was reading the "build matrix thread" and I've deemed it pretty subjective. I find it hard to believe no one has hard dyno numbers for their cars... Stock engines of our vintage make about 1 ft/lb per cubic inch, gross. Even 4-valve engines do little better. The 225 is rated 145hp and 215 ft/lbs. You're getting close with the hp with your modifications, but a nearly 30% torque increase when the low hanging fruit has already been picked? |
| Author: | Dan-o [ Mon Mar 24, 2014 7:23 am ] |
Quote: You have not put the 4bbl on yet, correct?
I'm interested to see the results as well. 3 inches of vacuum is a pretty significant bottleneck; and a half second at the track is nothing to sneeze at either.
| Author: | Exner Geek [ Mon Mar 24, 2014 8:53 am ] |
I have dynoed an engine similar to what you are contemplating. With 10:1 compression, ported big valve head, a Holley 500 2bbl on an Offy manifold, Clifford shorty headers, and a Racer Brown ST-22 cam, similar to a Mopar Performance 276 it made 215RWHP. That was with a standard transmission, drag strip times indicate about 240HP at the flywheel. I have also tried a 525CFM 4 barrel and noted no improvement. This engine runs fine on pump premium but I splash in some racing gas at the strip just in case it needs it. If you really want 240 RWHP in a streetable combination I think you need to think boost or a light nitrous shot. |
| Author: | Dan-o [ Mon Mar 24, 2014 9:09 am ] |
Quote: I have dynoed an engine similar to what you are contemplating. With 10:1 compression, ported big valve head, a Holley 500 2bbl on an Offy manifold, Clifford shorty headers, and a Racer Brown ST-22 cam, similar to a Mopar Performance 276 it made 215RWHP. That was with a standard transmission, drag strip times indicate about 240HP at the flywheel. I have also tried a 525CFM 4 barrel and noted no improvement. This engine runs fine on pump premium but I splash in some racing gas at the strip just in case it needs it. If you really want 240 RWHP in a streetable combination I think you need to think boost or a light nitrous shot.
Cool, sounds like it may be doable. As we autocross and cruise this car, I'm more focused on a "squared" motor. When I build my V-8's for performance duty, I like to see a squared motor, with 1hp and 1ft/lb per cid at the rear wheels. With the rod stroke ratio we have with the tall deck slants, I figured 1 ft/lb per cid to the rear wheels with .82 of that number in hp should make for a good little motor. I think that as of now, 240rwhp would be a bit much for my wife, as we have the car fairly over tired and under powered, so it's really hard to overdrive the car. As her skill set improves, we'll be looking to do the cam swap, probably over the summer. |
| Author: | RyGuyTooDry [ Mon Mar 24, 2014 1:23 pm ] |
The big problem with 225's is the head, it's too restrictive for the bottom end. Maybe see if you can do a little more work to the head to get it flowing better before tearing into the bottom end? |
| Author: | Sam Powell [ Wed Mar 26, 2014 9:09 am ] |
Quote: If you had more cam it would lower your dynamic compression which would allow you to run lower octane fuel. My previous NA motor used an erson cam 238@.50 duration 108lsa 510 lift with slightly over 10:1 compression ran on pump gas everyday as a daily driver. Your 264 comp cam is a pretty mild cam which would cause you to run into those ping problems when raising the compression.
Explain to me why a 264 cam is milder than a 238? Are these different things being measured? Is the 264 not measured at .050 as well? Thanks. Kev Sam |
| Author: | Joshie225 [ Wed Mar 26, 2014 9:42 am ] |
Sam, the Comp Cams 264S is advertised duration (usually, but not always .008" tappet rise) and is 220° @ .050" tappet rise. |
| Page 1 of 2 | All times are UTC-08:00 |
