| qa1 k-member, with slant six? https://slantsix.org/forum/viewtopic.php?t=54970 |
| Author: | killnine [ Wed Mar 26, 2014 10:39 pm ] |
| Post subject: | qa1 k-member, with slant six? |
Due to issues with my current slant six k-member in my 70 Duster (the LCA shaft hole is wallowed out), and the fact that I have QA1 LCA and UCA and strut rods already, I figured I'd just get the k-member from them too, which they have for this year. They go on and on about how it is a direct bolt in, etc. Well, we're picking it up tomorrow, but I suddenly realized, that despite their marketing, this thing probably doesn't have the right mounts for a slant six. It says it supports small block mounts and aftermarket mounts, but somehow I doubt this is going to work. Anyone have any advice, or ideas on how to mount the slant six onto something like a small block k-member? Luckily my wife is a journeyman boilermaker and a reasonably good fabricator. |
| Author: | slantzilla [ Thu Mar 27, 2014 6:53 am ] |
If I recall, the passenger side pad might be the same. The driver's side is different, so maybe you can get away with fabbing only 1 mount. If all else fails you can put it in on a motor plate. |
| Author: | killnine [ Thu Mar 27, 2014 9:23 am ] |
Schumacher says the driver's is the same, and the passenger will need to be fabbed. I guess we're in for some fun. I'll update with info and pics so if anyone does this at least it will save them some time. Quote: If I recall, the passenger side pad might be the same. The driver's side is different, so maybe you can get away with fabbing only 1 mount.
| Author: | Joshie225 [ Thu Mar 27, 2014 2:08 pm ] |
I think all you'll need to fab for the passenger's side is a big spacer. |
| Author: | Greg Ondayko [ Thu Mar 27, 2014 5:43 pm ] |
you could get a fron motor plate too. probably not realistic for a street car. if your wife is a good fabricatior the why not have her fix the original frame? a lot less $$$ and hassle. but if you want less weight and the cool factor qa1 would be the way to go. not hatin here, just thinking aloud. I hacked up and fabbed up my own stock k frame for my drag car project.. check on the 2 links to see. http://www.slantsix.org/forum/viewtopic ... &start=900 http://www.slantsix.org/forum/viewtopic ... &start=915 I thought about qa1, but could not get a weight on it and I could not afford it with everything else I was doing at the time. Greg |
| Author: | RyGuyTooDry [ Thu Mar 27, 2014 7:51 pm ] |
Hey Greg, what steering column are you running on that? Did you just take the outside tube off of the original? |
| Author: | Greg Ondayko [ Fri Mar 28, 2014 4:11 am ] |
Quote: Hey Greg, what steering column are you running on that? Did you just take the outside tube off of the original?
Here are 2 links that Explain what I have done with that.Read 2 pages of the first link and then some more trickery on the second link. http://www.slantsix.org/forum/viewtopic ... &start=540 http://www.slantsix.org/forum/viewtopic ... &start=735 Greg |
| Author: | killnine [ Mon Mar 31, 2014 12:04 am ] |
Greg I see you're from Irwin. I'm originally from up around Salem/Youngstown Ohio and Indiana, PA. I used to run a 68 Polara at Keystone with my buddy Bob, who ran a yellow Coronet. |
