It is currently Sat Nov 21, 2026 6:47 am
 Post subject: a390 info
PostPosted: Mon Mar 10, 2014 6:48 am
Can someone please help me with some info on the a390. Its originally a column shifted but looking to make it a floor shifter. I was looking for info on where 1,2,3,and reverse are I can move the first shifter lever on the tranny but the rear lever won't budge is this normal I'm hoping the reverse isn't locked up or the tranny is trashed.
 Post subject: Typically...
PostPosted: Mon Mar 10, 2014 7:14 am
Typically one lever or the other has to be in the middle position or neutral for the other lever to engage a gear...so if the front lever is in the middle then your should be able to mover the rear lever...if you had a driveline yoke to install in the tailshaft you can rotate the assembly a little to see if it frees up the other gear and allows it to shift.
PostPosted: Mon Mar 10, 2014 7:44 am
Thanks duster I'll try this when I get home
 Post subject: DI knows his trans
PostPosted: Tue Mar 11, 2014 5:38 am
Hi DI- didnt the first dusters in 70 have the 390 manual 3 speed with either column or floor optioned factory shifters. i think the floor shifter for the 390 was the inland not hurst model. later the 230 full synchro 3 speed became an option and had a floorshift or column option too. am i right? paladin
PostPosted: Tue Apr 01, 2014 11:35 am
well that worked. I'm trying to make shifte linkage but which lever is what I was thinking the rear is 1 and reverse but not sure there is no information on these transmissions anywhere. Can anyone help me with this
