| rigged up shifter https://slantsix.org/forum/viewtopic.php?t=54984 |
| Author: | Junior [ Fri Mar 28, 2014 9:36 pm ] |
| Post subject: | rigged up shifter |
has anyone tried to attach a shifter to the back of a transmission that doesnt have the bosses? like some kind of bracket that can be strapped on the tailshaft to bolt the shifter to. |
| Author: | kesteb [ Fri Mar 28, 2014 11:29 pm ] |
What shifter are you using? The universal 3 speed shifters usually have something that bolted to the tail housing bolts. |
| Author: | Junior [ Sat Mar 29, 2014 1:13 am ] |
the column shifter. its a manual trans. i would like to put it on the floor. all of the universal kits ive seen come straight back off of the tailshaft bolts. that doesnt work because the cross member is in the way. |
| Author: | Joshie225 [ Sat Mar 29, 2014 8:37 am ] |
Ok, so you've mounted the shifter. Somehow. What about the shift rods that don't fit? |
| Author: | Junior [ Sat Mar 29, 2014 12:32 pm ] |
i have a complete stock 3spd shifter from a board member that i could use to concoct something. the universals arent going to work. not even close. i had one bolted up on an extra transmission i had laying around to get the rod adjustment right, every one i have drove got stuck between gears. got it shifting beautifully. go to put it in the car and there just is no room with the cross-member in the way. |
| Author: | sandy in BC [ Sat Mar 29, 2014 2:17 pm ] |
Dont cut the crossmember without a plan. |
| Author: | Junior [ Sat Mar 29, 2014 2:22 pm ] |
im not cutting the crossmember for a three speed. maybe a 5, probably not even then. i dont like messing with structural parts of my car. so no worries there. |
| Author: | martin53 [ Mon Mar 31, 2014 10:26 am ] |
I made one for my A390 trans. It also had a column shifter. I had to use a price of angle iron and bolted it to two bolts on the tail shaft. Im posting from my phone but will post pictures when I figure out how |
| Author: | Junior [ Tue Apr 01, 2014 1:18 pm ] |
if you want to email me the pictures i can post them. or you can use a photo sharing site. i use photobucket. weesers1006@hotmail.com. |
| Author: | martin53 [ Tue Apr 01, 2014 2:48 pm ] |
I'll email them when I get a chance thanks. That transmission do you have |
| Author: | Junior [ Tue Apr 01, 2014 4:15 pm ] |
lol i dont even know. all i know is it does not have the bosses on it from the factory to mount a shifter on the tailshaft. |
| Author: | kesteb [ Tue Apr 01, 2014 11:11 pm ] |
In that case you will need to fabricate a mount. Most of the universal kits have "stuff" that will allow you to fabricate a mount for the shifter. They may even have directions on how to make that mount. But they will be generic, not specific to your particular application. In a A-Body the shifter is mounted behind the cross member and the shift lever rods, run across the top of the cross member. This means that you will need to cut hole for the shifter and clearance the floor boards around where the rods run. Then you need to make the mount. When I did this 30 some years ago, I ended up with a reversed shift pattern. Hopefully you will do better. |
| Author: | Junior [ Tue Apr 01, 2014 11:19 pm ] |
im gonna see what happens. just gonna run the column shift for a while. i have no problems shifting it. its smooth and i can do it quick when im not worried about punching the dash. or i might use doc's idea and just cut the extra tailshaft i have and use some exhaust clamps to hold the bosses on there. i dunno as of yet. just wanna get it running again. |
