| Timing mark jumping around 4-5 degrees https://slantsix.org/forum/viewtopic.php?t=55010 |
| Author: | Sean Mallory [ Wed Apr 02, 2014 6:57 am ] |
| Post subject: | Timing mark jumping around 4-5 degrees |
Can't be normal is it? |
| Author: | mattelderca [ Wed Apr 02, 2014 8:34 am ] |
Yes, if the cam chain is worn, or you have a distributor problem such as broken or missing springs on the advance mech. I assume this is with the vacuum advance disconnected. If not you can add that to the list of possibilities. Less likely is a slipping damper. |
| Author: | Sean Mallory [ Wed Apr 02, 2014 8:40 am ] |
thanks yes advance is disconnected the distributor is a new 'reman' and the old one did it too Looking like timing set replacement and maybe a new damper I guess. How big of a job is the timing set? |
| Author: | Doc [ Wed Apr 02, 2014 11:13 am ] |
Does the engine idle smoothly? A choppy idle can make the mark jump around. DD |
| Author: | THOR [ Wed Apr 23, 2014 10:50 am ] |
Quote: Looking like timing set replacement and maybe a new damper I guess.
Timing set isn't particularly difficult to do. If you are so inclined, a quick search on the board will net you the step by step instructions (with pictures!) on how to do the replacement. How big of a job is the timing set? I wouldn't worry about replacing the damper just yet. I recommend getting an answer to Doc's question above, and go from there. ~THOR~ |
| Author: | Sean Mallory [ Thu Apr 24, 2014 9:49 am ] |
Thanks, I am still trying to answer Doc's question. |
