Seeking more advice on rear axle options.
https://slantsix.org/forum/viewtopic.php?t=55011
Page 1 of 1
Author:  Sam Powell [ Wed Apr 02, 2014 2:13 pm ]
Post subject:  Seeking more advice on rear axle options.
I currently have the recently rebuilt 8.25 2.71 rear. It whines between 30 and 40 MPH only under light throttle. Getting this rebuilt cost more money than I have ever spent at one time on anything for this car besides paint. I have replaced the rear with junk yard parts twice, and those were relatively cheap at maybe $250 or so each time. At the time I chose the 8.25 over the 8.75 because they were cheap, lighter, and relatively plentiful. Looking back on it, it would have been cheaper to go 8.75 back then because of the continued availability of parts for them. I have so far spent more total than a new 8.75 would have cost back then. The guy who rebuilt the rear says he will listen to the present set up with me soon and let me know if there is hope of quieting it down.
However, I want to end up with a 3.21ish rear and overdrive. It seems like I thew most of this money down the drain. I am not sure I want to invest further in this rear if parts are going to continue to be a problem. I have gone on line and looked at all the options, including all the various Ford rears, and most of them are longer than will fit under the Dart. I have done a search here on this forum, andn there is good information, but not extensive that my searches turned up. I could not find an AHA moment there.
If I could be certain that the parts I ordered from Randy's for instance would fit, I would order the new gears, and have them installed. That is, if I can find a rebuilder locally here that can assure me he can set it up so it is quiet, and guarantee the work. I think it was Duster Idiot who said recently that there was a change in something about the pinion bearings on the 8.25 rears right about 1973, and I am not certain what year this rear is. So I need to know how I can identify it for sure for Randy's. Is there a part number stamped somewhere on the casting that would assure the correct parts are purchased?
However, maybe I am barking up the wrong tree here. Maybe the deal would be to replace this rear altogether. However, I have a nice disk brake conversion on this rear, and do not wish to lose that. I also have a big bolt pattern rear in there now, and would need to find a rear that has both disk brakes, and a 5x4.5 pattern, and is the right width.
I have to say this experience has shifted my thinking about this car. It is clear I can no longer think of it as a cheap hobby car. Since I cannot do this rear set up myself, I am beholden to, and restricted by what others can do in this regard. It has taken me about 3 weeks to get over the shock of spending so much money, and not only not being happy with the result, but having my identity regarding this hobby shaken.
There is much research to do yet, but just wondered what the prevailing thinking is here?
Thanks. Sam
Author:  sandy in BC [ Wed Apr 02, 2014 2:24 pm ]
I loved my narrowed Ford Explorer 8.8....
3,55 gears....Trac Loc 5x4.5 discs....parking brake..
......so I put it in my new project.
Its easy to narrow (any place that does driveline work can do it for $200)
Lots of ratios ....discs....many kinds of limited slip options
They are a dime a dozen at wreckers (2001 down Ford exploder with V8 )....buy an extra short side axle.
Author:  Sam Powell [ Wed Apr 02, 2014 7:31 pm ]
What year did you use? I assume the drive shaft will have to be modified? Different U joints? Did you rebuild it? Here is a dummy question: is there a way to tell if a rear in a yard is good? There is a great DIY localally here, but there are no guarantees. Good prices, but you take your chances.
Are there other smaller Ford SUV's that are RWD, with decent rears. I think I am going up to Crazy Rays tomorrow with a tape measure. That is actually the name of the yard.
Sam
Author:  Sam Powell [ Thu Apr 03, 2014 4:07 am ]
Here are the dimensions I copied from the internet so far. I think these are all either 8" or 8.8". Some have disk brakes and some have drums. Mopar A-Body axle is something like 57" or 57.125" wide. I think I could use a 58.75 axle, but do not know if the offset is the same side-to-side. I have only just begun to research this stuff. IRS I guess is on the table until I prove to myself it is not. I am not apposed to cutting the wheel well lip back a bit. Right now there is about 3/4" left on each side with a stock rear and 215/60x15" tires on 7" cop car wheels. I do not think I am rushing into anything this time.
86 to 93 V8 mustangs 58.75"
90 to 97 Ford Ranger 58.75
94 to 2003 Ford Exploders 59.75
90 to 95 Aerostar 59.75
79 to 2002 crown vick 62.8"
hope this helps
Plus...
84-92 Thunderbird V6/V8 = same as the 86-93 Mustang 4x4.25" pattern.
87-88 Thunderbird Turbo Coupe 61.5" w/disc brakes. 4x4.25" bolt pattern.
84-92ish Lincoln Mark VII & 82-end of rear drive production Continential also 61.5" wide w/ disc brakes, 5x4.5" pattern.
94-98 Mustang 60.25" w/disc brakes and 5x4.5" pattern
99-04 Mustang 61-5/8" w/disc brakes and 5x4.5"
For what it's worth... the Explorer 8.8" is the best in my opinion. (opinion of posting party).
65-66 Mustang 57.25 inches
67-70 Mustang 59.25 inches
71-73 Mustang 61.25 inches
77-81 Versailles 58.50 inches
It seems this Versailles rear might be a good choice if it has disk brakes.
I know nothing about the availability of parts for the various rears, or what all is involved with doing the mods Sandy had done to his.
Sam
Author:  sandy in BC [ Thu Apr 03, 2014 6:43 am ]
http://www.slantsix.org/forum/viewtopic ... ys&start=0
Author:  Sam Powell [ Thu Apr 03, 2014 8:21 am ]
WOW!!! Many thanks. Sam
Author:  Rick Covalt [ Thu Apr 03, 2014 2:09 pm ]
For some reason, I am thinking the Ford Granada 8" was almost a bolt in like the early Mustangs. Some of them may have got 9" rears also.
Rick
Author:  Dart270 [ Thu Apr 03, 2014 4:08 pm ]
I have Ford Granada 8" and Maverick 8" in two of my cars. Granada good for deep offset wheels, Maverick or 65-66 Mustang good for old style wheels. Pretty easy to get parts for.
Author:  Rick Covalt [ Thu Apr 03, 2014 5:44 pm ]
So I wasn't loosing my marbles!! :lol: :lol:
Author:  ceej [ Sat Apr 05, 2014 10:05 pm ]
Ford 8" out of a Maverick. Just slapped a set of 4.11's in the Valiant today. With a lot of help from Fopar and Black Rose!
Marvelous chunk! Put a Ford end on the south end of the driveshaft, and use over the counter U-joints. Key. The conversion U-Joints aren't right.
Author:  slantzilla [ Sun Apr 06, 2014 4:17 am ]
Lincoln Versailles and some Granadas had the 9" with disc brakes, but they weigh a ton. :shock:
Author:  Sam Powell [ Sun Apr 06, 2014 4:33 am ]
So is the dimension listed above for the Versailles, and the Granada the same? I have a line on a Granada rear now. Are they basically the same car. Interesting Ford gave one a Spanish name and the other a French name. I guess this was also the era of the Cordoba and genuine Corinthian leather.
I am told by Lou that the the company that made my disk brake conversion makes an adapter that bolts onto the Ford rear, so I can keep my brakes.
Yesterday morning I took the owner of the shop who set up this rear for a ride in the Dart, and he says in his opinion the current set up is not too bad. I don't know. I just know it sings more than my BMW by far. The guy who works for him and set up my rear has a Mustang he races, and has set up his own Ford rears many times. Maybe he will do a better job on a Ford part. He seemed happy when I told him of the plan to put a Ford rear in it. He also says the brakes from an 8" swap over onto a 9". So if this works, I will have a Ford rear with Chevy brakes on a Dodge. :)
Thanks for all the advice. Thanks to the smarts reflected here, I feel once again like I have a little clarity going forward.
Author:  slantzilla [ Sun Apr 06, 2014 9:14 am ]
Versailles was a rebadged Granada. Those were great times in the auto world. :lol:
Author:  DusterIdiot [ Sun Apr 06, 2014 10:58 am ]
Post subject:  Lol...
Yeah, it's a Mercury, so it has to sound like it has a fancy name over the Ford version so the customer thinks they are getting a budget Lincoln (no different than the Plymouth platform vs. Dodge/Chrysler...Anyone got a St. Regis?)...
:roll:
