| nut Nuts NUTS!!! https://slantsix.org/forum/viewtopic.php?t=55017 |
Page 1 of 2 |
| Author: | Eatkinson [ Thu Apr 03, 2014 12:12 am ] |
| Post subject: | nut Nuts NUTS!!! |
Was preparing to take off my single-pot stock MC to finally upgrade to the dual-chamber Raybestos. Tried loosening those darn threaded flare fittings that screw into the junction block, since I bought a new block that will replace the original. Of the four threaded fittings that screw into this block, one is the 'original' solid brass fitting that happens to be a larger (and much more practical) hex size. THAT one (of course) broke loose without too much problem. The other three fittings are newer, and they look like brass but they're not: they're steel or something else magnetic. They are extremely soft metal. I had to replace all my brake lines back in 2010. The guy who replaced all the lines for me must have tightened these buggers down hard. I'll be damned if I didn't manage to easily round off a couple of these pseudo-quality fittings from my gentle but firm hauling on them. I had soaked them in p-blaster for a couple days before putting a wrench to them. I even tried 'tightening' them first before loosening them but now I don't know what to do. How do people get these fittings loose without destroying the brake line in the process? I'm ok with replacing some short sections of front line, but the minute I destroy the nut/fitting that holds the rear brake line to the block, I'm having to replace a large, long section of brake line that I'll have to re-bend in all the right places and flare. I really don't wish to have to do this. I can't believe how difficult these stupid flare fittings are being The metal is so cheap. What do people suggest I do? |
| Author: | Junior [ Thu Apr 03, 2014 12:26 am ] |
im assuming you are using a line wrench? when they dont work i use vise-grips. grab it hard enough that you are not squishin the fitting but firm enough to make sure you are getting a good bite and not just going to completely round them off. if you sqeeze it to much you will lock the line in there and wont be able to get the wrench back on it. just use them to break them free not to back them out all the way. im also usually not to worried about messing up the lines because when i am undoing them i am usually replacing the lines anyway. |
| Author: | makapipi [ Thu Apr 03, 2014 12:32 am ] |
| Post subject: | tight fitting |
To prevent wrecking line, watch the line closely while turning fitting and stop if line starts to twist. apply little pb oil in hole where line goes into fitting. allow to soak in, not too much if goes into brake fluid can swell seals cups. there is a tool vise grip wrench, similar to regular vise grip, but has flat half hex jaws to grab on to bolt like a wrench, i used the small 6 inch one and manage to loosen a rounded fitting. on you tube one person used regular vise grips. |
| Author: | Danarchy [ Thu Apr 03, 2014 6:46 am ] |
![]() ![]() I use a combination of tools, and usually end up destroying a nut or line, especially when they have been on there for years! |
| Author: | Kidd [ Thu Apr 03, 2014 9:12 am ] |
my method is much like a few posted. Spray the bajeezuz out of it with PB blast. I then use a form of Vice Grip depends on how I can get to it really, but I do use Vice Grips.I "tighten" it just a tiny smidge.Then loosen it a bit.I guess a little back and forth so the line wrench can work without twisting the line. |
| Author: | Eatkinson [ Thu Apr 03, 2014 9:39 am ] |
Quote: im assuming you are using a line wrench? .
You assumed wrong. I've been using a simple open-end wrench. The amount of 'rock' they have on the nut was really too much for me, but I didn't see what else I could use.Have seen line wrenches before but didn't know their application. I'll have to pick up one and give it a try. |
| Author: | Reed [ Thu Apr 03, 2014 10:06 am ] |
I always use line wrenches, and when that fails I use a hacksaw and a tubing flaring tool. |
| Author: | Junior [ Thu Apr 03, 2014 2:07 pm ] |
| Author: | wjajr [ Thu Apr 03, 2014 5:46 pm ] |
If none of the above works, cut the tube close enough to get a socket over the stuck fitting, it will come free. You will need to stabilize the junction block with a wrench being careful not to deform any of its female ports. Stuck corroded brake fittings are a way of life in Maine. |
| Author: | SpaceFrank [ Fri Apr 04, 2014 6:46 am ] |
Ditto to everything that's been said so far. If you do end up having to cut the lines, do you have any slack to just re-flare the ends? I've seen actual brass line fittings at auto parts stores before. The tool for double flaring isn't that expensive, but doing it can be tricky. You may want to practice on a scrap piece of tubing before trying it in a cramped space on your actual brake lines. Screwing up and cutting it off again costs you more slack that you might not have. Just double check that you've actually put the end fitting on before you do the flare. Not like I've ever screwed that up or anything... cough cough. |
| Author: | Danarchy [ Sat Apr 05, 2014 7:18 am ] |
Quote: I've pulled as hard as I can and no luck. Should it? How have other people separated the two?
PULL HARDER! |
| Author: | Rick Covalt [ Sat Apr 05, 2014 7:24 am ] |
While the M/C is in the car I pull up on the brake pedal until the rod comes out of the back. It is much easier while it is bolted in place. Rick |
| Author: | Pierre [ Sat Apr 05, 2014 8:09 am ] |
I never bothered with the boot. Any I pulled out were rotted and crumbled and didn't have replacement so just did without. For the rod - I've used two methods. Assemble everything back in the master cylinder. Put the rod in a vice with the cylinder pointing to the ground or at least sideways. Then you can beat on the cylinder flange with a sledge. Alternatively - put the piston in a vice, then grab the rod with pliers. Heat the piston with a torch. Eventually the rubber piece interlocking the rod and piston will give way. You can also cut a slot the length of the piston with a dremel or cutting disc. Go little at a time until you break through the piston but not so deep to nick the rod. Do it again on opposite side of piston. There is a piece of rubber locking the rod to the piston. It's maybe 3/16" wide, with hole in middle. A new one should have come with your new master. The ridge you felt in the piston - it sits in that ridge. There is also a corresponding ridge on the rod. The outer diameter of the rubber is just slightly over the inner diameter of the piston. When installed, it compresses to let it get in the piston, then expands into the groves securing everything. This is a safety. In car, the only thing preventing the pedal from moving backwards (say you get your foot caught under the pedal without realizing it...) is the breakable plastic brake light switch. If it moves out far enough the rod will come loose of the piston and, well, uhoh. If your going to use Rick's method remove the switch. His car may have the switch in a different place. |
| Page 1 of 2 | All times are UTC-07:00 |
