| Manifold heat valve https://slantsix.org/forum/viewtopic.php?t=55032 |
| Author: | Aaron65 [ Fri Apr 04, 2014 12:39 pm ] |
| Post subject: | Manifold heat valve |
I was out puttering around on the Dart today, putting new motor mounts in, changing the oil, etc., and I noticed the manifold heat valve was frozen. I got it loose, but it's far from "free." Does anyone know which direction is open on one of these? Until it's totally free, I want to make sure it's letting the exhaust straight out. Thanks! Oh yeah, this is on a '65 170. |
| Author: | jhdeval [ Fri Apr 04, 2014 12:49 pm ] |
The top edge lays toward the block the bottom edge towards the wheel so clockwise will open counter to close. |
| Author: | Aaron65 [ Fri Apr 04, 2014 1:18 pm ] |
Great! Thanks! It looks like it was frozen shut. |
| Author: | Aaron65 [ Fri Apr 04, 2014 7:13 pm ] |
Quote: The top edge lays toward the block the bottom edge towards the wheel so clockwise will open counter to close.
Just to make sure I'm thinking straight here...if I rotate it counterclockwise, all exhaust is going out the pipe, and not being diverted up to the carb. Is that right?
| Author: | Fopar [ Fri Apr 04, 2014 8:27 pm ] |
Been a while since I have looked , but I think that sounds backwards. Richard |
| Author: | jhdeval [ Sat Apr 05, 2014 7:47 am ] |
Quote: Quote: The top edge lays toward the block the bottom edge towards the wheel so clockwise will open counter to close.
Just to make sure I'm thinking straight here...if I rotate it counterclockwise, all exhaust is going out the pipe, and not being diverted up to the carb. Is that right? |
