It is currently Fri Nov 27, 2026 5:30 am
PostPosted: Thu Apr 10, 2014 9:20 am
74 scamp 225/a904.
Been working on this car for a friend. I am now pulling my hair out. It came to me missing a bunch of parts. I installed new battery, cables, silinode, Atlternater, voltage regulator, a bunch of wiring repairs, at that time installed HEI, stock coil was shot and we where already working in that area on wires why not up grade. So we did and I was able to start the car, engine ran but crazy rough. Still had no cooling system and while running, engine puked oil out of every gasket.
Engine had even and strong compression numbers, engine was pulled, head was milled to get 8.9-1compression was around 7.6 before. Head reconditioned, on bottom end inspection found engine had been rebuilt .030" over all bearing and pistons rings good shape, it was decided just new gaskets needed and installed new timing set(dot to dot). Repainted everything and then installed engine, radiator, new hoses every where, new gas tank and sending unit.
So my problem is no starting. I have fuel out of the pump through the filter and the carb (yet still suspect) enjects a stream from the inside while throttle cracked(no heavy fuel smell from repeated cranking). So pretty sure it is getting fuel.
Now it has to be spark. Checked wiring 12v to relay, key on power to relay, power out of relay to +side coil and B side HEI module. Have ground to back side of module /heat sink, and ground strap back over to coil(ford E-core from 460 truck). Secondary side coil runs to post next to the b side. Distributor wire to opposite side of module. Ok now with test light I have power to both sides of coil and module. Took coil and module to auto parts store both check good. Have spark on spark plug tester coming from coil wire to dist. Then pull plugs and they have spark when grounded to side of block but very intermittent not consistent. So pulled the distributor, pulled cap and inspected the reluctor gap and found it way out of spect and a couple teeth chipped. Bought remanufactured dizzy set its gap to 0.008" found TDC on number one cylinder by timming marks on balancer checked the verified by looking through oil cap hole both valves look level. Dropped dizzy in hole rotor pointing to area of number 1on cap closest to the vacuum pot.
We crank and crank every thing turns my spark at the plugs got more consistent. We just can't get the engine to run/start. It does poof out of the carb after much cranking and then waiting and then cranking again. Even spraying starter fluid in carb yields no difference.
What am I missing I am sure it's stupid and simple but I and baffled.
PostPosted: Thu Apr 10, 2014 9:38 am
Doesn't spitting back out the carb imply that your spark is on the wrong stroke?
1968 Plymouth Barracuda [Daily Driver]
1972 Dodge Dart Swinger [Lent out as Daily Driver to a friend]
2010 Challenger R/T 6 Speed
PostPosted: Thu Apr 10, 2014 10:53 am
Did you time it at TDC on the compression stroke? Don't forget that the timing mark will be at TDC on both the compression and exhaust stroke.
Try spinning the rotor 180 degrees.
PostPosted: Thu Apr 10, 2014 12:36 pm
You should TEST your ignition system output. Get an adjustable spark tester like Thexton # 458 ($21 at amazon) - plug it onto your coil spark wire & connect the ground clip securely to the engine block/head somewhere. Stay clear of the tester while checking coil output!! Set the gap to 1/2" (HEI should jump a 3/4" gap while running-ie, at full 14V power) & crank the starter- you should see big consistent spark.
If you're pulling the distributor to reset position, then while it's out, plug the pickup connector back in, turn the key to run & spin the dizzy by hand, should get lots of sparks.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Apr 10, 2014 1:56 pm
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Thu Apr 10, 2014 10:27 pm
X2 on swapping the pick up wires...and firstly checking your timed to TDC on the compression stroke. There's info around here somewhere regarding the correct polarity of the pick up,but at the end of the day it's a 50/50 chance,just swap wires if it doesn't run. You intermittent spark seems to indicate this is a possible issue...When I did the HEI conversion I actually got it right first time round.....had me surprised! Out of curiosity I swapped the wires to see what happens....big difference! Certainly worth checking
PostPosted: Fri Apr 11, 2014 2:56 am
2 of the last 4 sets I installed were stamped 1 tooth off! Last one I did was perfect.
Also a major vacuum leak at the intake to cylinder head interface can play havoc with starting. Ask me how i know? :oops:
PostPosted: Fri Apr 11, 2014 3:34 am
clockwise rotation for dizzy? recheck firing order, try moving dizzy advanced one tooth...just started my rebuild two weeks ago thought I had dizzy in right but one tooth is all it took to get it running. Oh yeah, only took 2 minutes to pop the head gasket w\o bleeding cylinder head through temp sender hole. Valve lash is fairly critical...found that out too.
PostPosted: Thu Apr 17, 2014 8:40 pm
Ok today was the first day back on the car. I rechecked all of the ignition connections, had them all correct. Turned engine over by hand to TDC mark on balancer to hole in timing tab. Stabbed distributor back in place rotor to #1 hole. Capped off vacuum tree on intake and carb.
Now started thinking about this what does an engine need to run. And what changed from before I freshened up the motor. Fuel (replaced gas tank, sender and hoses, did fuel line mod) pump is shooting out fuel and carb is squirting with throttle movement. Fire/spark HEI hooked up same as before coil checked good, ignition module checked good, new dizzy(cap, rotor, and wires) all plugs pushing blue spark. Now starting to think I know the dizzy is in the right spot, maybe Rick is right about the timing set being a tooth off, not going to be a fun fix again, but wait what else does the engine need (COMPRESSION) what changed about compression on this engine. We shaved .080" off the head and did a valve job. When I cleaned the rocker shaft assembly I just soaked everything as an assembly and then rinsed and reinstalled. I never messed with the rockers as I knew once running I would have to adjust them. Needless to say all the valves where smashed down. Loosened everything up set to cold lash of 0.010" intakes and 0.020" exhaust and it fire right up. Thanks Valianteer for the lash idea.
So now it fires up but won't stay running unless it has 1/2 throttle imput and it's way rough. But at least it starts and now I can begin the tuning process. Thank you guys for all the ideas.
PostPosted: Thu Apr 17, 2014 11:11 pm
Did you swap the pick up wires like has been mentioned in many previous posts? It DOES make a big difference. Also,just setting the timing tab on TDC and fitting the distributor is a 50/50 chance of getting it right....you need TDC on the compression stroke.....that being said if it runs you probably got it on the correct stroke...If it were me I would check these first before playing with cam timing... if the cam timing was actually off you would have weird compressions,have you checked? I've seen slants with timing chains worn so bad they skip a tooth,they run pretty sluggish,but they still seem to get the job done....just!
PostPosted: Sun Apr 20, 2014 1:01 am
Got the engine running set fast idle started adjusting valves again and it was smoothing out, then the engine died. Tried restarting and it would not turn over. The bottom end locked up tight. Had a 6foot cheater bar on the crankshaft bolt with plugs removed and no movement at all. I then realized i didnt have any oil pumping up to the top end when playing with the valves. I know for a fact the oil sump is installed. My guess is oil pump failure or fresh clean oil pulled bad sludge from some passage inside the motor and cloged up. Now I need to find another short block to drop in.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
