| Need help choosing engine parts https://slantsix.org/forum/viewtopic.php?t=55035 |
| Author: | Feather_Duster [ Fri Apr 04, 2014 9:17 pm ] |
| Post subject: | Need help choosing engine parts |
Does this cam need to be replaced? I know it is a normal wear pattern, but how worn is it? [/img]I was trying to avoid rebuilding my slant, but after finding broken valve stem seals and a double blown head gasket, I'm thinking the engine is pretty tired. I'm pretty sure it's all original. This is for a feather duster, so I would like to rebuild with high MPG (~30ish?) in mind. Of course, I wouldn't mind a little more power too, but I think even a stock rebuild would feel peppier than what this engine is now. I don't have much experience with engines... What components/brands are recommended? I just don't want to put in some garbage that leaves me worse off than just keeping the worn original parts. Any brands to avoid? I've seen the engine build matrix - Aggressive Ted, your torque and mileage build seems interesting. What could be changed on your build to gain some extra mpg? I have not been to the machine shop yet, so I don't have any measurements. BTW, can anyone recommend a shop in north Florida? |
| Author: | DusterIdiot [ Sat Apr 05, 2014 12:09 am ] |
| Post subject: | The tricky question.... |
The big thing to ask, are you going to put all the Feather Stuff back on the engine? If so, you will rebuild the engine to stock specs and go from there...If you go for something like Ted has, the Feather distributor curve will not help much there, and the EGR wont help suppress the knock of the massive spark advance on the higher compression....9then you end up spending more money to set it back with something else... This becomes kind of a quandry....more power can be built with mileage using Ted's build, but you will have to do some distributor recurve work and some carb tuning...it's kind of tough when a stock rebuild on a 1976 Feather with stock parts dialed in and operating correctly and a 2.94 rear with the A-833 OD will give 30-32 mpg highway on the flats typically (mine would go about 28mpg 50/50 average highway and city driving on a tired high miler OEM setup....)... -D.Idiot |
| Author: | Aggressive Ted [ Sat Apr 05, 2014 11:03 am ] |
Quote: I've seen the engine build matrix - Aggressive Ted, your torque and mileage build seems interesting. What could be changed on your build to gain some extra mpg?
DI has good points.....Some more thoughts to consider....... My set up is like a truck build since my Dart is heavy, 3600 lbs. but, with a 8 3/4, 2.76 ratio Sure-Grip, a gear ratio you wouldn't use in a truck. My goal was to keep the rpms (2500 rpm max) low at freeway speeds, with the 2.76 ratio (I tried 2.94 and 3.23 also) and 26" tall tires and retain the 904 automatic. I do a lot of driving to and from work, 120 plus miles a day. You could do the same thing with an overdrive and lower gears, and a stick but to make the switch is expensive. The Swinger is a brick and not as aerodynamic as the Duster. So to help mileage I use a air dam under the car and dropped the nose about 2". Something Doc told me to do.....Another item was to ditch the stock fan and go with electric fans. This provides quicker warm ups in the morning and less heat soak for better mileage. I also run water/alcohol injection instead of the EGR to knock back timing from 60 degrees which I love to run because is it also provides for better mileage. If your engine was rebuilt you could run low viscosity synthetic which really helps on friction losses and windage on a SL6 providing better mileage. Another item from Doc was to get rid of all the junk in the trunk and lighten the car up as much as possible. Also he suggested driving with a vacuum gauge....that really keeps you honest providing better driving habits and better mileage. I have a long list of things that I have found to help like upgrading the ignition system, wiring, the heat deflector under the carb like MOPAR added, an air/oil separator, which would help you right now. The current temporary engine I am running now has no valve seals and has 284,000 plus miles on it and all this winter on local driving I averaged 22.4+ mpg through the ice and snow. I drive about 250 miles and fill up which is usually 11 gallons, or if I go 300 miles it takes 13 gallons. Basically I tuned the brick to be as gentle on gas a possible, weather it is a stock motor or my torque build which gets much better mileage since I can run higher average vacuum. The recurve is vital to making the engine behave and sip gas. Click on the red link below my name to view pictures. You can go to slide show mode for bigger photos and read the captions. |
| Author: | ceej [ Sat Apr 05, 2014 11:35 am ] |
Judging from what I can see of that lobe on the right, your cam is shot. It may be the photo, but it looks like you have heavy damage. Don't know about the fuel pump lobe. It looks like it's seen better days as well. Take it to a re-grinder and ask. I think you'd be money ahead to get a new one. CJ |
| Author: | xjarhead [ Sat Apr 05, 2014 11:37 am ] |
Would crank scraper and windage tray be benifical in helping milage? Dave |
| Author: | Aggressive Ted [ Sat Apr 05, 2014 11:55 am ] |
Quote: Would crank scraper and windage tray be benifical in helping milage?
Dave,Your going to get a variety of opinions on this one...... I would say yes, especially at freeway speeds when you run a full five quarts of oil or more. I have learned to run just 4.5 quarts with a new filter in a SL6 as it has helped on mileage for me the past 20 plus years. The PCV doesn't suck as much oil mist. That is with a stock baffled valve cover......Now that I have a clear air/oil separator I can actually monitor it. Running a full 5 quarts will fill the air/oil separator in a week. Running 4.5 quarts and it takes about a month of driving before I need to drain it. I use a SMP V180 PCV with the metal barrel, not the noisy cheap plastic PCV. |
| Author: | xjarhead [ Sat Apr 05, 2014 2:03 pm ] |
Thanks Ted. I will try the 4.5 quart of oil and see what happens. Dave |
| Author: | Feather_Duster [ Sat Apr 05, 2014 2:53 pm ] |
Thanks everyone. Thanks for the pics too, I will probably do some of those mods. I am now leaning toward a stock rebuild internally, perhaps with a windage tray, and simply modifying external items as suggested by Ted to possibly increase mileage further. It would be nice to have some torque though... I remember this engine being quite sluggish, but the fact that the head gasket was blown between 4 cylinders and the timing was off was not helping. Are there any internal items that are universally accepted as being better than stock replacement in terms of mpg AND performance? Like, does everyone go with a specific cam because it gives you +20HP and +5mpg. Something like that. What brands to buy? I don't want to install junk. Specific part recommendations would be appreciated. -Ben |
| Author: | Aggressive Ted [ Sat Apr 05, 2014 4:00 pm ] |
Feather_Duster, I hate sluggish SL6's.......they are no fun! Compression is your friend if you want to build a torque monger. Even if you stick with a stock cam, however I would not, get one of Doc's RDP RV10's from Erson at a minimum or have yours reground like I did......from Delta Cams or Oregon Cams. If your going through all the work of a rebuild, make it a torquer. It will be a lot more fun to drive and reward you with much better mileage. |
| Author: | xjarhead [ Sat Apr 05, 2014 4:03 pm ] |
Check out this thrread lots of great info there http://slantsix.org/forum/viewtopic.php?t=54953 Dave |
| Author: | Feather_Duster [ Mon Apr 07, 2014 10:16 pm ] |
Thanks for the link, Dave. After some thought, if I can get 25+ mpg mixed and have some power to make the car fun to drive, that would be great. This car was so weak when it was my daily driver, it's hard to imagine it being able to break the wheels loose. I had to avoid certain hills in town b/c if I had to stop, I wasn't sure it would be able to make it up them. Ted, you are starting to sell me on the torquer... But DI brought up some good points about knock, etc. I'm ok with changing out the distributor/recurving it, but would like to avoid the water/alcohol injection. Is knock going to be an issue? Ted, looking here, http://www.slantsix.org/forum/viewtopic.php?t=43155 , if I'm understanding this correctly, Doc seemed to think the RV10 might improve the torquer vs your Delta E254 regrind. Did you ever end up swapping it out? FYI, here is what I currently have: 1) single barrel carb and intake 2) All stock 1976 225 block and head 3) A stock (possibly too worn out) cam 4) A-833 OD 5) 8 3/4 sure grip 3.23 6) 205/60 R15 7) weight should be around 3000 lbs? Would the torquer with a RV10 be a good fit? |
| Author: | Aggressive Ted [ Wed Apr 09, 2014 5:49 pm ] |
Dave, Wow! with a stick and that gear ratio you can burn rubber with just a recurve and 10 degrees of initial. You must have very light springs or broken springs in your distributor and long slots on the governor if your getting a ping. I would fix that first! even if the engine is shot, that will wake it up. If you want to avoid knock/ping limit the initial and mechanical advance to 30 degrees and do the rest with the pod. The pod is out of the picture when you step on it and the vacuum drops. It is just initial and mechanical. I didn't think there were any hills in Florida! Out here our lowest pass is a 3000 foot climb. The grades near our house are 7 and 9 percent. I figure if it doesn't ping on them, I am good to go! especially with an automatic. I go for max timing that is why I use alcohol/water injection to mellow it out. It is cheap and easy only costs about $20.00 to do and keeps the engine nice and clean internally, nice steady idle too! On cams, the Erson would be preferred if you want to spend the money and have the time. A regrind made sense for me as it was quicker and because of the amount I had milled off the block and head offset the reground cam to were I could reuse my stock push rods. Everything evened out, offset each other and came out perfect! The regrind was $45 plus regrinding the lifters came out to $55. The Delta reground cam is still in the block. Doc's description of the RV10 is very good! He helped me with my build since I was in panic mode.....a.cheap oil filter collapsed internally and wiped out engine and I was driving 120 miles a day. I was thrilled as it came out great however......, I would really like to try the RV10 to feel and experience the difference. What carb is on your engine? Maybe it needs a rebuild and some modification. Do you know what jet is in it? You can always set it up for a healthier pump shot to spin those wheels! Sounds like you have a nice car! At least it is light and has a aerodynamic body style. Won't take much to make it scoot! |
| Author: | Feather_Duster [ Sat Apr 19, 2014 9:03 pm ] |
I'm not currently getting ping, I was worried about it with the high-torque build. Well, there aren't any real hills in Florida... but there are brief steep sections. I always had trouble getting out of steep driveways... the engine just bog down. I'm not in a hurry, any idea how much a RV10 is? Is that the whole part number? A Holley 1945 is in it, but after looking up the part number, it seems to be for an automatic. Not sure what jet is in it. I'm in the process of restoring it... maybe it will be nice one day! I actually wasn't planning on doing anything to the engine, but it looks like it needs it. -Ben |
