It is currently Thu Nov 26, 2026 11:24 pm
 Post subject: What the DIPSTICK ?
PostPosted: Sat Apr 12, 2014 8:24 pm
I was running around this morning picking up some things for the house and car when I heard a ticking noise from the engine. It went from slight to loud then quit I pulled into a parking lot and looked in the engine compartment and did not see anything obvious and did not here the noise any more. I went to check the oil later on pulled out the dipstick and found that the end of it was broken off up to where the LL is for full :shock: . WHY? the stick has allways been straight. What could grab and break it like that? Now I have a piece of metal loose in the oil pan. I just hope it comes out when I dump the oil.
my first 6 1973 Plymouth DusterImage
PostPosted: Sat Apr 12, 2014 8:47 pm
6 Pack Dart
They get caught by the crank, I form mine toward the drivers side with a small arc in the stick.
Richard
PostPosted: Sat Apr 12, 2014 9:53 pm
The last motor I took apart had three of those pieces in the pan…
