It is currently Sat Nov 21, 2026 4:54 pm
PostPosted: Mon Apr 21, 2014 7:56 am
Drove the Dart to a customer's house up in Western Maryland at highway speeds. When I arrived the automatic temp was 200 measured coming out of the trans. It was a cool morning. The engine had worked up a sweat also as it was running a fever of 220 with Evans coolant and a 180 stat. The trans cooler also has a 180 thermostat on it.
Is the 200 temp for auto ok? Should I put an auxiliary frame cooler on maybe. I will pay attention to temp on level ground going back tonight.
Sam
PostPosted: Mon Apr 21, 2014 8:17 am
200 is fine. I wouldn't worry unless it starts getting above 230 and stays there.
PostPosted: Mon Apr 21, 2014 7:18 pm
Thanks Dennis, I misread the engine gauge. It was only 210 after climbing a pretty long mountain road. On the way home, with more downhill running the trans never got over 190. Since this is an aftermarket trans cooler, I had no real way of knowing if it is big enough for the job. I appreciate the guidelines. I guess if it gets hotter than 230 in the summer heat I will consider an additional cooler on the frame.
Sam
PostPosted: Tue Apr 22, 2014 12:38 pm
Although it's comparing apples to oranges, we are able to check the transmission fluid temperature on our 2010 4.7 liter 4wd Ram though the engine management display. On the highway it reads a pretty constant 160F to 170F. I really haven't looked but I'm guessing it has an aux cooler.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
Users browsing this forum: Bing [Bot] and 15 guests
