convertible drainage points.
https://slantsix.org/forum/viewtopic.php?t=55094
Author:  slantfin [ Sat Apr 12, 2014 3:16 pm ]
Post subject:  convertible drainage points.
Putting on the new top. I see the gutter where the top is attached, but am wondering where the water is supposed to finally exit the quarter panel. Is there a drain that needs to be cleared?
Author:  wjajr [ Sun Apr 13, 2014 9:28 am ]
My Dart just drips from the gutter down to base of quarter between wheel and door.
Author:  Doc [ Tue Apr 15, 2014 4:27 pm ]
The factory also had small "drains" with tubes, installed at the bottom of the well liner, and the tubes lead into the q-panels.
Author:  AussiePlymouths [ Wed Apr 16, 2014 4:47 pm ]
Yeah Doc is correct (again) BUT, check your well liner.
When I got my '63 I was puzzled as to where the water would go.
Found out thru FABO, but when I checked my for drain tubes they weren't there.
Maybe that's why I had to weld in new rear floors??? lol
Author:  slantfin [ Mon Apr 21, 2014 1:02 pm ]
This thing is mostly patches, born in New Hampshire. I'm vacuuming out a lot of sand from the quarter panels, and thinking of a hail Mary shot of rust converter before I move on with the top. The well liner might need some fixing up too.
