| high idle problems https://slantsix.org/forum/viewtopic.php?t=55098 |
| Author: | DeeceDartSix [ Sun Apr 13, 2014 10:11 am ] |
| Post subject: | high idle problems |
I am having a problem with a rebuilt slant. '70 Dodge dart with a 225. just recently got it running after replacing just about everything underneath the hood and doing some engine work. The car starts up, and idles very high (between 1600-1700 rpm). I have a 4 barrel holley on there (model 4160). Originally, i thought it was a vacuum problem, however im getting a reading of 25 psi on my vacuum gauge. messing with the idle screw on the carb yielded no solution, as the lowest rpm i can get is still 1500 psi. maybe related, the car diesels when its run for a long time. moving the idle mixture screws yields no solution. any suggestions or tests i can run to come up with a solution would be greatly appreciated. |
| Author: | wjajr [ Sun Apr 13, 2014 3:46 pm ] |
Is this a new 0-8007 390 carburetor or used? New out of the box it should be close provided no vacuum leaks, and you are not operating at high altitude. If used, you have several things probably going on. First make sure high idle cam is returning to rest once choke is open, and check to be sure electric choke spring will allow full retraction. Then check static timing and set it around 10*to 12* if higher, try to close secondary throttle plate turning its shaft and see if idle reduces. If idle speed slows by closing secondary throttle plates, that indicates that adjustment is acting like a vacuum leak and needs to have its stop adjusted per instructions. Pull carb off manifold set primary throttle plate so that only about 0.025†of transition slot is showing at most, and secondary throttle plate cracked open enough to expose idle fuel hole. Once you get the carb idling on idle circuits and not into transition circuit, and any excess air from vacuum leak and or secondaries cracked open too far, the idle adjustment screws will work. Also make sure power valve is not ruptured, and float level is adjusted correctly. You need these two books on tuning Holly Carburetors, [url=http://books.google.com/books/about/Super_Tuning_and_Modifying_Holley_Carbur.html?id=M3gq1v61qiYC]here[/url], and [url=http://books.google.com/books?id=_fTHcnYMyywC&source=gbs_similarbooks]here[/url], check out [url=http://www.bob2000.com/carb.htm]this site[/url], and Holley’s site for 8007 [url=http://www.holley.com/data/Products/Technical/199R8108-2rev2.pdf]instructions[/url] and Holley’s [url=http://www.holley.com/0-8007.asp]technical pull-down button[/url] for how-to videos & frequent questions. |
| Author: | bmimken [ Sun Apr 13, 2014 6:48 pm ] |
Dieseling is a sure sign of a vacuum leak in my experience. Brian |
| Author: | ValiantBoyWonder [ Sun Apr 13, 2014 8:33 pm ] |
If you hook the vac advance to a constant vac source on the carb that will happen. |
| Author: | DeeceDartSix [ Sun Apr 13, 2014 9:15 pm ] |
turns out that the high idle cam was stuck wide open. i adjusted the screw so that its all the way closed. engine sits at a healthy 800 rpm now, and 400 while in gear. it might need a bit more tuning on the floats and mixture screws, but its running great now. i watched a few helpful videos on the holley website to find this out. awfully strange that the high idle cam was stuck wide open when the carb just came out of the box. thats not something thats supposed to happen is it? |
| Author: | wjajr [ Mon Apr 14, 2014 6:31 am ] |
Anything can happen. One has to double check everything new these days. Glad it was an easy fix for you. Still get those books so you can fine tune that carb, and understand how it works. |
| Author: | DeeceDartSix [ Sat Apr 19, 2014 4:09 pm ] |
i will pick up some holley books. Knowledge can always help to prevent future problems with these things, so it always helps to learn as much as you can. Thanks much for the help guys - im sure ill need it again in the future. |
