| Near Death Experience this morning https://slantsix.org/forum/viewtopic.php?t=55126 |
| Author: | 64ragtop [ Wed Apr 16, 2014 7:19 pm ] |
| Post subject: | Near Death Experience this morning |
The AZDart has been a veritable feast of little minor things that are now mostly comfort/better driving experience items until this morning. The car starts easily with one pump of the pedal and runs at fast idle just as it should but it takes for bloody ever to move the temp gauge off the low peg. This morning's oncoming traffic was a couple of blocks away so I pulled out with maybe a bit more throttle than usual and the engine just QUIT! That oncoming was a lot closer now, but fortunately the Dart started easily and I got out of the way of that big RAM truck! I'll call it "no blood, no foul". What I think happened was that "bit more throttle than usual" showed me that the choke hadn't opened up enough to handle the extra fuel. Did I mention the butt clench marks on the seat? Tomorrow morning, I'll time the choke opening and see if I can speed it up a bit. It's a Carter BBS. Someone please check me on this - moving the choke pointer toward the "L" opens the choke quicker, right?? BC |
| Author: | mattelderca [ Thu Apr 17, 2014 5:05 am ] |
I bet you want the opposite! I'll bet you want more choke for a longer duration and the cut out you experienced was due to not enough choke. If it takes a long time to warm up you might want to check the thermostat. |
| Author: | wjajr [ Thu Apr 17, 2014 6:00 am ] |
[quote]If it takes a long time to warm up you might want to check the thermostat.[/quote] On a stock engine choke stove reacts to manifold temperature, not coolant temperature. Make sure heat riser valve is free to operate and able to direct hot gasses to base of carburetor & intake manifold, and its passageways clear of buildup. Secondly if choke is still mostly closed, a full or close to full throttle plate opening will override a partially closed choke and open it significantly, than once throttle is closed (acceleration period ended) choke returns to its previous normal warm up opening position and continues to open via choke stove spring which its opening rate is adjustable. A weak accelerator shot causing a lean stumble is more noticeable on a cold engine, and in conjunction with the above forced choke opening at WOT will exacerbate lean stumble or cause a stall. If you have an electric choke it needs to be calibrated to open slower better matching heating of intake manifold during warm up. It is a fine dance between opening too fast and too slow with these chokes because an electric choke is a timed event by how fast a bimetal spring with electrical resistance deforms when 12v is applied at the moment the ignition is switched to “Onâ€, and is devoid of manifold temperature input being the side of the equation that determines drivability. |
| Author: | 64ragtop [ Thu Apr 17, 2014 4:16 pm ] |
Quote: On a stock engine choke stove reacts to manifold temperature, not coolant temperature. Make sure heat riser valve is free to operate and able to direct hot gasses to base of carburetor & intake manifold, and its passageways clear of buildup.
I hadn't thought of that! Thanks!!Quote: Secondly if choke is still mostly closed, a full or close to full throttle plate opening will override a partially closed choke and open it significantly, than once throttle is closed (acceleration period ended) choke returns to its previous normal warm up opening position and continues to open via choke stove spring which its opening rate is adjustable. A weak accelerator shot causing a lean stumble is more noticeable on a cold engine, and in conjunction with the above forced choke opening at WOT will exacerbate lean stumble or cause a stall.
I've observed that there IS an accelerator shot, but never thought it might be weak. It seems adequate in normal driving, but this was with a cold engine. Can I overdo giving it a stronger shot and what's the downside if I do?Thank you very much for the leads. Your analysis makes sense. Looks like I need to get my hands dirty! BC |
| Author: | RustyRamcharger [ Sun Apr 20, 2014 2:18 pm ] |
If you have an electric choke, it has to be wired through a resistor and a 3-terminal oil pressure switch. Wiring it directly to the ignition circuit will open it much too quickly, and also damage the choke thermostat. Ken |
| Author: | 805moparkid [ Sun Apr 20, 2014 2:20 pm ] |
what size air bleeds do you have in the carb? |
| Author: | '67 Dart 270 [ Sun Apr 20, 2014 2:23 pm ] |
| Post subject: | longer choke |
I agree with Mattelderca, seems like you need the choke to stay closed longer, not shorter time. my two cents. brian |
| Author: | 805moparkid [ Sun Apr 20, 2014 2:32 pm ] |
| Post subject: | Re: longer choke |
Quote: I agree with Mattelderca, seems like you need the choke to stay closed longer, not shorter time.
im kinda lost as to where the op is, either tx or Az, either way you guys have to realize its high 70's at 7am, no choke needed. What he is actually probably happening is LEANING out due to to large of a low speed air bleed. I bet his was like mine, like .080". He solders and drills it .025-.035 and i bet he wont even need the choke
| Author: | lowbrowsickser [ Sun Apr 20, 2014 7:16 pm ] |
very similar thing happened to me on a warm engine. I'm not sure what caused it, just not gonna put my self in that situation again. I've a "new" slant in progress |
| Author: | Aggressive Ted [ Mon Apr 21, 2014 9:37 am ] |
I have experienced what 805moparkid described. If they are too big, you can go lean when you need it. I have had that happen many times after a long hard run, hot! So don't go too big on the idle bleed unless your running a #64 or bigger jet. |
