It is currently Fri Nov 27, 2026 4:09 am
PostPosted: Sun Apr 13, 2014 2:16 pm
Putting the crank in a 170. I have a set of TRW Main Bearings, Standard.
Question is this, The set is MS2517, 4 boxes are marked MB 1999 (Qty 1), MB 2000 (Qty 3). One of the MB2000 is the thrust bearing. The MB1999 is the number one bearing? I think I see a small chamfer on the front edge, not on the other ones. No instructions with the bearing set. Any feedback? Thanks!
PostPosted: Mon Apr 14, 2014 4:22 am
I don't have the TRW numbers handy, but it sounds like you're thinking is correct.
The thrust bearing, number 3, has the flange. Number 1 is the same as 2 and 4 except it has the champher on the edge of the bearing (also should have a paint mark). Number 2 and 4 are the same.
PS: A lot of the "newer" main bearing sets do not have the champher on the number one bearing. When I run into this, I just file the edge of the bearing at about a 45 degree angle. That champher is for timing chain oiling.
 Post subject: Bearings
PostPosted: Mon Apr 14, 2014 6:23 pm
Thanks Charlie. All the plain bearings have a paint mark on the edge. I put the 1999 number at 1 and the 2000 bearings at 2 and 4.
PostPosted: Tue Apr 15, 2014 7:27 pm
Dang, I didn't even know about the #1 bearing chamfer. I'll make a point to do/check that on my next install...
Thanks!
PostPosted: Wed Apr 16, 2014 5:01 am
When I use the "newer" bearing that don't have the chamfer, I just use a file and put the chamfer from the groove to the front of the bearing. The factory bearings had the chamfer the across the full width of the bearing. If you are doing timing chain oiling mods, similar to what Doug suggests, the chamfer would be redundant.
PostPosted: Thu Apr 17, 2014 1:55 pm
Yep, cool. I have been putting a small groove in the #1 cam bearing to get more oil out there.
Users browsing this forum: Ahrefs [Bot] and 30 guests
