| will not idle https://slantsix.org/forum/viewtopic.php?t=55136 |
Page 1 of 2 |
| Author: | Junior [ Thu Apr 17, 2014 12:03 pm ] |
| Post subject: | will not idle |
finally got enough stuff bolted to my heap to fire it up. im running a more or less stock motor with 264s cam and 340 valve springs. the engine ran fine with my 390 vacuum secondary carb. it now has a 650dp with the secondaries disconnected so that keeps me well within the 390cfm realm. its for a turbo setup. it runs great. takes 4-5 shots with the acc pump to get it to fire then starts revs fine and holds rpm like nobodys business. will not idle at all though. in the past when i tried to put a bigger carb on this motor i had the exact opposite of what is going on now. it would idle beautifully but wouldnt do anything else, would just die as soon as i touched the gas. im at a loss here. i figured my problem would be getting it to rev not idle. its acting like i have a huge vacuum leak but there are none. you could save both of us the trouble by not telling me the carb is to big. i know its on the bigger side. people have run them with good results. hopefully one of those people will chime in. |
| Author: | Joshie225 [ Thu Apr 17, 2014 12:25 pm ] |
Check the secondary throttle opening. Double check for vacuum leaks. |
| Author: | Junior [ Thu Apr 17, 2014 1:03 pm ] |
i just double checked for vacuum leaks. i cant find anything. manifold to head is good, carb to manifold is good. i took off the vacuum lines that i had ran and plugged all of them. still nothing. the secondaries are closed. i checked and rechecked that. they dont budge when its running either. i pulled the bowl and the metering plate to double check the passages are clear and they are. |
| Author: | Reed [ Thu Apr 17, 2014 1:14 pm ] |
Valve adjustment? Choke adjustment? |
| Author: | Junior [ Thu Apr 17, 2014 1:16 pm ] |
valves are good. i did them last time i had the vc off. 1k miles or so. for $#!+ and grinns im gonna throw my 390 back on there for a minute and see what happens. |
| Author: | Junior [ Thu Apr 17, 2014 1:53 pm ] |
sorry didnt see it last time. there is no choke on this carb. threw my 390 back on and its doing the same thing. i know this carb ran good. pulled my intake to check for the compression on my remflex gasket and it looks good. im at a loss. |
| Author: | wjajr [ Thu Apr 17, 2014 1:57 pm ] |
Check the vacuum secondary diaphragm for rips. Also while its on the bench check the trueness of carburetor's base with a known straightedge and a light. I had a carb once that had a deformed base from over tightening, and vacuum leak was so big no amount of spraying carb cleaner would give an indication of any leak. Filing the base flat in several directions with a #12 or 12 mill bastard file will true the base if you find this problem. |
| Author: | Junior [ Thu Apr 17, 2014 3:04 pm ] |
mechanical secondaries. ill check the base. i put everything back together. its a little better but still not right. |
| Author: | Junior [ Thu Apr 17, 2014 3:33 pm ] |
Quote: I had a carb once that had a deformed base from over tightening, and vacuum leak was so big no amount of spraying carb cleaner would give an indication of any leak. Filing the base flat in several directions with a #12 or 12 mill bastard file will true the base if you find this problem.
nailed it.<img src="http://i125.photobucket.com/albums/p79/weesers1/IMG_20140417_182259_339_zps7b3ded08.jpg" border="0" alt=" photo IMG_20140417_182259_339_zps7b3ded08.jpg"/> <img src="http://i125.photobucket.com/albums/p79/weesers1/IMG_20140417_182242_766_zpsc5ffde79.jpg" border="0" alt=" photo IMG_20140417_182242_766_zpsc5ffde79.jpg"/> now what is a bastard file? im assuming its just a big metal file. i never knew there were mills or numbers to them. i have a bunch of files. i dont think any of them have numbers on them. am i just looking for something that isnt quite a rasp and not quite nail file? |
| Author: | Junior [ Thu Apr 17, 2014 3:36 pm ] |
just googled bastard file. i got a couple of those. ill give it a try tomorrow. thank you so much. |
| Author: | 64ragtop [ Thu Apr 17, 2014 4:21 pm ] |
Nice pics to illustrate WJAJR's catch on the problem. Another reason I love this site!! BC |
| Author: | Junior [ Thu Apr 17, 2014 4:39 pm ] |
Quote: Nice pics to illustrate WJAJR's catch on the problem. Another reason I love this site!!
i was thinking the same thing.
BC |
| Author: | Junior [ Thu Apr 17, 2014 4:40 pm ] |
well i think the file did the trick. now i flooded it lol. im running out of daylight so ill get back at it tomorrow. |
| Author: | Junior [ Fri Apr 18, 2014 11:52 am ] |
got back to it today. filing didnt work. tried my 390 again that isnt working either. still dont know whats up. there is a chance the 390 is gummed up from sitting but i doubt it. i rtv'd the gaskets and carb so im waiting for that to setup to try it again. im open to ideas if anyone has anything to add. |
| Author: | Junior [ Fri Apr 18, 2014 12:31 pm ] |
quick question. if i were to take the idle mixture screw out completely shouldnt i have gas coming out of the hole they go in? |
| Page 1 of 2 | All times are UTC-08:00 |
