1969 225 to replace the 1977 225?
https://slantsix.org/forum/viewtopic.php?t=55144
Page 1 of 1
Author:  slantin_77 [ Fri Apr 18, 2014 11:38 am ]
Post subject:  1969 225 to replace the 1977 225?
I bought a 225 engine out of a 1969 Plymouth Valiant and I want to take it apart a bit to replace some parts and put it in my 1977 Dodge truck. Should everything be a simple swap? Take the 1977 engine out and drop in the 1969 engine? I've never done this before but I know that there is an oil issue with the 1977 engine (haven't checked the pressure just yet) and the mileage is unknown. The 1969 engine I was told has 80k miles on it when he pulled it out of his car to replace with a 318. I also have a Super Six intake setup that Id like to put on the engine as wel. Any info would be greatly appreciated. Thanks!
Author:  Joshie225 [ Fri Apr 18, 2014 11:58 am ]
Swap the oil pan and pickup tube, mind the crank pulley in case you have AC in the truck and remember to buy the right spark plugs. Everything else should fit fine.
Author:  DusterIdiot [ Fri Apr 18, 2014 4:27 pm ]
Post subject:  x2
I would also be tempted to replace the timing set to make sure that the one in the 1969 isn't "loose" causing problems down the road...and to make the best of the situation, I would also be tempted to use the 1977 cam and matching lifters in the 1969 engine with the super six intake, and degree the cam in 4 degrees advanced. But that's splitting a few hairs and a few meager HP for the effort, if you have time and experience though it's not that hard.
Author:  slantin_77 [ Sat May 03, 2014 10:37 pm ]
Ok, thanks for the tips! I dismantled a lot of the '69 engine this weekend and checked all the rod/main bearings and they are in excellent shape, so that's good. And when I rotate the crank, seems like all the cylinders are "hissing", which means the compression is still good too.
So is swapping the cam and lifters out of the '77 going to give noticeable gains, or isn't it worth the hassle? Also, why is the pan different? And I actually would like to replace the crank pulley, but not sure how...there's no nut or bolt on the front of it, which makes me curious as to how you would remove it.
Anything else I should check? Are there any parts that are '69 specific that I would need to buy for it? I have an oil pump I bought for the '77 engine...should that still be the same? I would ultimately like to replace all of the exterior components (fuel pump, oil pump, distributor, etc). As always, any help is greatly appreciated!
Author:  DusterIdiot [ Sun May 04, 2014 8:56 am ]
Post subject:  If..
If you are already pulling it apart to check it out and replace the wear components then a cam swap wouldn't be too hard, the 1972-1980 cam is a better "stock" cam so you will get a little power gain and degreeing it in will ensure it's where it should be not retarded for smog or slipped, if the compression check showed it was in real good shape swapping to an RV cam would be better from the torque stand point.
You are swapping the oil pan and pick up screen as they are different than the car version (i.e. look at the sump location).
Just swap in your distributor, clean up your old oil pump if it's good and keeps good pressure, melling has been hit or miss lately on quality. Unless the 1969 damper is slipped, I would use it and it's timing cover.
