| 8.75" Sure Grip Follow-up https://slantsix.org/forum/viewtopic.php?t=5515 |
| Author: | huskynox [ Thu Apr 17, 2003 11:04 am ] |
| Post subject: | 8.75" Sure Grip Follow-up |
If I grab the drive line by hand and try to twist it, it feels normal. I think the backlash on the ring and pinion is good. I looked at the gears before I installed the third member and they looked perfect. I'm thinking it has something to do with the sure-grip?? What happens when the Auburn Gear style sure-grips go bad? Has anyone had any experience with this? Thanks Mike in WA |
| Author: | Doctor Dodge [ Thu Apr 17, 2003 7:59 pm ] |
You will first feel the ring and pinion backlash but if you turn harder, you will over-ride the clutch action (pre-load) and feel the side gear / inner pinion gear backlash. So put a wrench on the yoke and turn it harder to see if you can feel more free-play. DD |
