It is currently Tue Jul 14, 2026 12:34 pm
PostPosted: Sat Apr 26, 2014 9:52 am
i am finally getting everything buttoned up on ruster after a wintr of disassembly and fabricating to make new parts fit.
I have a few holes in the firewall that I route the wires through, but the holes are much larger than the wires passing thorough.
do I need some kind of covering for the empty space or can I get away with the fan motor hole and the wiring bulkhead hole being uncovered?
thanks, Greg
PostPosted: Sat Apr 26, 2014 10:43 am
Car Model: '23 T-bucket
Sorry, no. You gotta plug 'em. I might suggest just a patch panel of aluminum, screwed over the hole(s), with some appropriate sealant, with a grommet through it for wiring protection.
Roger
PostPosted: Sat Apr 26, 2014 11:37 am
Car Model: Toad Wagon
Ditto.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Apr 26, 2014 1:31 pm
For the smaller wiring holes NAPA usually has a plastic boxed assortment of nice grommets that will help.
PostPosted: Sat Apr 26, 2014 3:19 pm
thanks guys.
Much appreciated
