It is currently Fri Nov 27, 2026 7:21 am
 Post subject: Custom Headers
PostPosted: Mon Apr 21, 2014 11:43 am
So I don't have the money for a set of headers and am wondering how difficult it would be to make my own. I have seen the intake/exhaust flanges on ebay fairly cheap. From there Is there anything special to keep in mind?
I am also thinking this would be a good project to practice welding on.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Mon Apr 21, 2014 11:57 am
ive though about doing it myself. i probably will sooner or later. my thought was to get the ebay flanges and a set or two of small block headers cheap. should have all the bends you need.
what kind of welder are you using?
PostPosted: Mon Apr 21, 2014 1:14 pm
I have the mid level Harbor Freight one 170 amp. I have some experience on my father in-laws little craftsmen one but this one is a 220 volt unit while his is 110 so I figure there will be a learning curve.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon Apr 21, 2014 1:29 pm
if you are using gas you should be fine. at least it will look clean. i use a flux core and wile the welds look fine, the slag is pretty crazy. either way it will work.
PostPosted: Mon Apr 21, 2014 8:19 pm
Anybody have tips on any gotchas?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Mon Apr 21, 2014 8:23 pm
what have you done to the motor? if its dead stock and going to stay that way look into like a 1 3/8" primary but if your going to upgrade later i would just do 1.5".
im not even convinced most any of the NA cars need 1 5/8" but i just havn't had a small tube header to test that theory with until now
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Mon Apr 21, 2014 8:39 pm
By the time you buy the flanges, tube stock and welding materials...add the hours you have into it, you could have worked overtime at work a couple of days and bought a pair of headers. I got my Hooker Super Comps for $250 on eBay.
PostPosted: Mon Apr 21, 2014 11:09 pm
Have you welded something that thin before, let alone tube at all sorts of odd angles? It's more challenging then you think. Wet your teeth on a more basic welding project (using thicker metal) then attack headers.
PostPosted: Tue Apr 22, 2014 10:25 am
Building a set of headers is a labor of love. You can not sit and think about how much money it is costing you.
I had a set built for my Daytona that were done by a buddy with an exhaust business. I got the flanges from Aaron on E-Bay, and Jeff got the collectors from Schoenfeld. He used 1-3/4" tube. I would have rather had 1-5/8", but he didn't have enough tube and his supplier makes him buy 100' at a time or it is big bucks. I turn mine close to 7000, so I doubt the bigger tubes will hurt anything.
Jeff MIG'd them together and then we ground them smooth. After they were done another buddy saw them and offered to TIG them. :oops:
For a stock motor I would use at least 1-1/2" or you are wasting your time. You may be able to find a place online that will sell shorter quantities than 100'. You can also find bends and donuts you can cut for your bends.
PostPosted: Tue Apr 22, 2014 11:02 am
I am not running a stock motor. I have enginbldr's intake and exhaust valves. I have trimmed the head and block to 10.5:1 compression. Ported and polished the head upgrade to a super six setup.
I realize that this is not going to be easy but rather then laying out money I don't have right this second I can at least try. I don't expect it to be easy but I am hoping to eek out a bit more performance.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Apr 22, 2014 11:32 am
I ordered a universal hotrod header kit from summit or jegs for 80 bucks and purchased the flanges from ebay (I don't recall flange cost).
Make sure the flanges are bolted down to work bench or spare engine to avoid warping anything. I enjoyed making mine cut all the pipes up and used the curves and straights I needed tacked it all together and trial fitted a million times. Then mig welded it all up and had it ceramic coated. I like the welded look at the time but now I regret not grinding everything smooth it would have looked sweet. My primaries are 1 5/8 or 1 3/4 don't remember without measuring them. Oh and I built mine around a 1bbl stock intake on a spare engine but when I bolted the clifford 4bbl intake on I had a few minor clearance issues. So use the intake your going to use for sure during mock up lol.
Kev
