It is currently Sat Nov 21, 2026 4:55 pm
PostPosted: Sat Apr 12, 2014 4:16 am
need my unit looked at
still no reverse..
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Apr 12, 2014 2:12 pm
bigslant6fan on this site might it, I believe. He is in MD near DC.
 Post subject: ok
PostPosted: Sat Apr 12, 2014 4:57 pm
so do I need to got thought all th emember ship 2find said member/.
slant six's RULE!
 Post subject: did a search found him
PostPosted: Sat Apr 12, 2014 5:26 pm
http://www.youtube.com/watch?v=M4K7XZGeHTE
slant six's RULE!
PostPosted: Sun Apr 13, 2014 1:40 pm
Look in the trans section. You will see his posts. There is a local shop in G burg I like very much. He can do whatever you want. Until recently he campaigned a dragster every season. His shop is called Transtech.
Sam
PostPosted: Mon Apr 14, 2014 11:16 am
Online
Lou gave you Charles' Username on this forum.
Send him a PM.. He is not far from you in Tanneytown MD.
he can possibly help you out.
Charles Knows his transmissions.
 Post subject: talked to..........
PostPosted: Tue Apr 22, 2014 6:28 pm
talked on phone to bigslant6fan. he's not a fan of the transbrake so 2speek.
basically said it's either mech or a pressure issue. told me 2get a 400 psi trans gauge and check those 1/8 pipe threads below the pan casting on the trans. for pressure should be 350 ish.
so.
reading various posts all over the inet, basically states that it's the electric switch that operates the reverse. well mine is old school with an external relay.had 2mode trans case to mount so I will make various steel rods that go from the solenoid to the valve body via a hole on the side as mounted.
slant six's RULE!
Users browsing this forum: Bing [Bot] and 15 guests
