It is currently Fri Nov 27, 2026 7:10 am
PostPosted: Sun Apr 20, 2014 8:41 pm
So my oil dummy light keeps coming on and im not sure why...I removed the sending unit on the pump and hooked up a pressure test gauge and it read between 45-50 which is normal. I have ordered a new sending unit just in case the one installed went bad.
Anyways, I had bought all new Equus gauges from O'Reilly (speedo, tach, oil psi, water temp, fuel level and volts). Now to install the oil pressure gauge, do I hook up the gauge to where the sending unit is? Like remove the sendi g unit and thread in a fitting for the gauge? I dont know what I did with the instructions to be honest and I've never installed gauges before.
-Brodie
1977 Dodge D100 stepside, slant six/3 on the tree
2002 Chrysler 300M Special (daily driver)
PostPosted: Mon Apr 21, 2014 5:50 am
Yes. Or you can install a "T" fitting and use the gauge and the light switch.
PostPosted: Mon Apr 21, 2014 6:30 am
+1
1964 Dart GT
PostPosted: Mon Apr 21, 2014 9:25 am
+2 Same here! :D
PostPosted: Tue Apr 22, 2014 6:23 pm
Car Model: '65 Valiant 170 T5
I tagged a bracket onto a 'T' and remote mounted the switch combo (OE light switch and another for the electric fuel pump) on the firewall. Can see it just to the right and under the fan motor (one of the motor's fasteners holds it in place). Connecting it to the oil pump is a length of 1/8" copper tube with a vibration relief coil in it.
Thom
Cross-threaded is tighter than Lock-tite
Users browsing this forum: No registered users and 30 guests
