| '67 clark cortez rebuilt 225 Slant6 in a 72 Dart? https://slantsix.org/forum/viewtopic.php?t=55171 |
Page 1 of 2 |
| Author: | DougFrankenstein [ Tue Apr 22, 2014 3:11 pm ] |
| Post subject: | '67 clark cortez rebuilt 225 Slant6 in a 72 Dart? |
I seized my engine in my 72 dart due to my oil plug busting and leaking all of my oil on the freeway. I found this engine on craigslist and it is a rebuilt 225 from a 67 clark cortez. It seems to be in good condition from what i have found out from the seller. what i would like to know is how this engine will work in my car, and what complications there might be, or things i'd need to know or look out for. any help would be great. http://ventura.craigslist.org/pts/4421035058.html |
| Author: | slantzilla [ Tue Apr 22, 2014 6:49 pm ] |
Biggest roadblock is the '67 motor will have the small pilot crank flange. Your torque converter will not fit. |
| Author: | Aggressive Ted [ Wed Apr 23, 2014 9:00 am ] |
It is like a truck motor, dual roller chain......should work great! |
| Author: | DougFrankenstein [ Wed Apr 23, 2014 12:31 pm ] |
This engine is my cheapest option. Would I be able to replace the crank flange? |
| Author: | Reed [ Wed Apr 23, 2014 1:03 pm ] |
Only by swapping the crank. Which could be done if both motors were removed at the same time. |
| Author: | Danarchy [ Wed Apr 23, 2014 1:13 pm ] |
Can you use the adapter ring? and a differant flex plate? that different pilot crank flange from early to late confuses me. |
| Author: | Pierre [ Wed Apr 23, 2014 1:33 pm ] |
Early is smaller. Late is bigger. You can use a late (larger) crank with the adapter ring (to turn it into a small crank) but the only way use a early crank with late converter is to have the ID machined out. If his crank was run without oil to point of motor siezing it's probably gonna need some work before it can be used again. |
| Author: | Reed [ Wed Apr 23, 2014 2:05 pm ] |
I suppose you could pull the crank form the Cortez motor and have a machine shop mill the crank end. Or find a good used 68-up crank. |
| Author: | Danarchy [ Wed Apr 23, 2014 2:29 pm ] |
or find a transmission? On a related subject, someone should post a stickey on years of engine, trans. swaps(early<Late, Late>early...) it would be appreciated and helpful! |
| Author: | DougFrankenstein [ Wed Apr 23, 2014 3:47 pm ] |
This 67 engine is my cheapest option right now, but i am exploring my options. I originally wanted to save my original engine, but i am not mechanically knowledgeable enough to rebuild it myself and am not sure if i have enough money to get it rebuilt at a shop. I do have a few friends with an engine hoist and the proper tools, but without the knowledge of my engine. This is my situation. Would it be suggestible for me to attempt to pull the crank from my 72, or buy a different crank, and put it in the 67? i'm at a bit of a loss here. |
| Author: | Fopar [ Wed Apr 23, 2014 4:07 pm ] |
You could ask the seller to measure the hole in the crankshaft, as the engine is in the open. Richard |
| Author: | Doc [ Wed Apr 23, 2014 4:22 pm ] |
| Author: | slantzilla [ Wed Apr 23, 2014 8:31 pm ] |
The easiest option is to get a small pilot converter built. Edge can probably do it for a couple hundred bucks. You will also need the externals off your car engine, manifolds, pan, pickup, etc.. |
| Author: | Charrlie_S [ Thu Apr 24, 2014 3:59 am ] |
I am a fan of Edge converters, and Andre can built that type of converter. But I think Dacco converters, has them as a on the shelf item, possibly for less money. The Edge converter would be a custom unit (I have three of them), while the Dacco unit, would be a stock style converter. I did send Dacco an e-mail inquireing about this. I will post when I hear back. |
| Author: | 64dartdoug [ Thu Apr 24, 2014 11:42 am ] |
1968 A904 changes: * slant six and small block engines began using a larger counterbore in the crankshaft and a larger torque converter snout. The newer diameter is 1/4" larger. 1968 & later torque converters cannot be used with 1967 & earlier cranks for this reason. * earlier A-904's used a fine spline input shaft. In 1968, the A-904 adopted the course spline input shaft since the input shaft's spline engages the torque converter, the torque converter must match the input shaft. So, you can use a 66-67 torque convertor and flexplate, but you'll need to change the input shaft on your 72 904 tothe input shaft from 66-67 904. you could probably get entire 66-67 A904 for G/RG engines for $100, maybe in working condition, and swap in it as well. If the cortez has been sitting a long time, you'll probably need to open it up and have a peek. If its been outside, hopefully it hasn't rained down the carb into the manifold. You'll also need a 67-76 A-body oil pan (AND OIL PICKUP) most likely. The Cortez pan is probably a bigger truck pan, or a B/C-body sized pan which probably won't fit. If your '72 pan and pickup are still good, use them. |
| Page 1 of 2 | All times are UTC-08:00 |
