It is currently Sun Nov 29, 2026 10:34 am
PostPosted: Sat May 10, 2014 5:11 pm
Car Model: 87 B150, 1970 Valiant 4-door
I searched a few different ways. Came up empty.
(Just finally picked up a used stand. I was going to upgrade some hardware on it. While at it, figured I'd get everything to mount the engine to it too.)
Thanks in advance.
PostPosted: Sun May 11, 2014 3:40 am
You use the bell housing or auto trans mount bolts. Just find the ones that fit the back of the engine. There are several different sizes depending upon location. You will want to put healthy washers between the heads of the bolts and the engine stand arms. I think there are some 3/8ths and some 5/16ths ones there. I will not swear to that though. Just use the ones that fit.
Sam
PostPosted: Sun May 11, 2014 3:58 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
and be careful when turning it over!
Richard (aka Fingers)
PostPosted: Sun May 11, 2014 8:44 am
Car Model: '63 Valiant wagon, '70 Duster
Just to be on the safe side, I usually use Grade 8 bolts, not the cheap stuff.
 Post subject: Vg-265
PostPosted: Mon May 12, 2014 1:02 pm
That looks bad ass...
65 Coronet, 4 bbl, .060 over, mild cam.
66 Valiant, Black, 3spd, Hyperpak, headers.
works in progress...
PostPosted: Tue May 13, 2014 1:23 pm
Thanks for the replies.
I was going to replace a lot of what is installed on the stand w/Grade 8, then also get bolts for mounting engine.
I guess I'll just get 4/ea of 5/16 & 3/8" coarse @ 2", plus thick large diameter washers to match.
Hardware stores around here suck, so I was going to do McMaster or Fastenal. (I don't trust the local stuff labeled "Grade 8" to be anything more than Chinese garbage.)
To that end, I wanted to order all at once.
Thanks again.
PostPosted: Tue May 13, 2014 2:50 pm
I have used the Grade 8 bolts from Home Depot and haven't had any problems.
PostPosted: Tue May 13, 2014 3:08 pm
Mounted mine using standard grade 5s. Just make sure they are long enough to get a good bite into the threads in the back of the block, and as mentioned above, be careful rotating that big-ol slant. Especially with the head on, she is a very top heavy engine that will pull your arm out of socket if your not paying enough attention.
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
Users browsing this forum: No registered users and 15 guests
