It is currently Fri Nov 27, 2026 8:10 am
PostPosted: Thu Apr 03, 2014 10:26 pm
You guys may remember I've been slowly... s..l..o...w...l...y....
doing the clutch in my 75 d100.
Late here and I'll be out all day tomorrow - but may be able to read a
reply to this on my phone if anyone has an idea.
Replaced the pump - think the 225 has about 140k on it... cleaned
oil pan... fairly bad... based on some reading of related threads
here I wonder if some crud either clogged the filter, or I didn't set
something (bypass valve?) in the pump as I should have, or
the oil too thick with 1qt lucas stabilizer mixed in + crud.
Did prime pump and verify that oil coming out at pump and up top.
Shut it right off after hearing knock. Friend helping isn't a mechanic
either but he definitely also heard it change to a heavy knock.
Current thoughts/ suggestions I have are the filter clogged, to replace
and change oil for straight 10/30 or perhaps 5/30, something really
light. I guess I could take more time and read more threads about this
- it's just that the truck is in a friends garage and (even though the place
is huge and it's not really in the way) if it needs to go to my mechanic
friend's to await engine help I guess I'd rather know sooner rather
than later.
I tried to read and ask guidance about this and thought I was being
cautious given my relative inexperience, but, well... here we are.
Sort of assuming I've spun a bearing for the moment but hoping it's
not that bad. Not sure if trying the above will just make things worse
or if something else might be going on.
Ideas appreciated.
DCello
You mean there's a Slant Six FORUM!?
PostPosted: Fri Apr 04, 2014 4:21 am
Forgot - new standpipe with (much?) stronger spring - perhaps
this matters?
Might have stretched the old spring but had ordered it anyway
by the time I read about someone doing that...
-DCello
PostPosted: Fri Apr 04, 2014 5:54 am
Okay - I can take it - somebody tell me the bad news -
I see a lot if views but no one wants to break it to me -
Or maybe I'm in the running for the Idiot of the Month
Award and you haven't finished voting yet?
Guess I'll look forward to learning more about
Engines?
DCello
PostPosted: Fri Apr 04, 2014 6:24 am
more info needed to get any kind of reply. Can you locate the knocking(with stethoscope, tubing or stick)? Which cylinder? When I got my car it had a spun bearing(#5) and it would idle smooth, but anything above idle was like a Gremlin trying to escape the block with a hammer!(it had 182K)
1964 Dart GT
PostPosted: Fri Apr 04, 2014 6:31 am
You mention replacing the pump. Was there something wrong with the old one?
10-30 is what I run, and is about the heaviest that should be in a slant. What do you have in there? There isn't any of that Lucas crap in there, right? Filter is new? If it was plugged it should be bypassing. Should. Go get a new one.
New pump, new gear. Was the old pump gear chewed up?
You had the bypass taken apart on the new pump?
PostPosted: Fri Apr 04, 2014 7:40 am
Do you have oil pressure? If yes, how much? If no, is the oil pump gear intact?
PostPosted: Fri Apr 04, 2014 10:17 am
okay - and thanks all for responding-
thus far:
won't get back to it til tomorrow but,
-knock from below - pretty sure I torqued flywheel bolts properly & loctite red
-will get out the stethoscope
-10\30 with 1qt Lucas stabilizer + 1\2 pint zinc additive
-plan on new filter + 10\30 + zinc, nixing the stabilizer (!)
-plan on cutting open old new filter to check filter material
-could I pull the bypass if filter seems clogged to see if it looks contaminated?
-hadn't read as much at the time I started this and since had the engine in a good spot to change oil pump thought it would be prudent (hah!?)
-saved the old pump to check later but haven't yet
-didn't disassemble new pump relief valve but wonder if should have checked or set it?
-pressure switch light went out when priming and pump would fill old oil cartridge with media and top removed - used chisel and snips to minimize risk of filings. filled cartridge maybe ten-twenty percent in a few seconds of cranking.
-plan to buy or try to dig up a gauge - not sure where or best to get- would prefer to scavenge a good one than pay for a piece of crap.
-oil pump gear looked okay but haven't done a careful comparison to
photos online if such are in the articles - just nothing looking obviously
chewed up.
- I did look through the bearing website one of the forum members (doc?)pointed out and it was enough, together with recalling slant six Dan's flush admonitions, to give me a good scare, to wit, I wonder if I should have gone through a flush at least prior to adding anythingnlike the stabilizer (if I would have added it at all from what you've said) which might have tipped the filter anywhere near bypass mode.
At times I feel like I tend to stumble into arcane ways to screw up a good thing, and that's probably happened here- enough crud to screw up one or more bearings, which the filter would have caught with ease, but I go and add something to push it into bypass mode before all that crap was filtered out - doh!!!
- so here's the next obvious question : how might one bypass the bypass mode to a secondary filter to try to catch this, preferably with some gauge to tell you its happened so you could replace the first filter? Probably - well, almost definitley more than I could do but maybe you guys are already doing something like that?
thanks all!
DCello
PostPosted: Fri Apr 11, 2014 9:04 am
Oil pressure 50psi (not warmed up).
Knocking so bad even an untrained ear (mine)
Told me to just shut it off after a minute, which I
did.
Locals telling me time to pull it.
DCello
PostPosted: Fri Apr 11, 2014 10:28 am
Online
A loose flywheel will make a big ruckus too. How pretty sure are you?
PostPosted: Fri Apr 11, 2014 3:13 pm
Inspect the oil pump mounting gasket very carefully you maybe sucking air at the oil pump inlet side this has been a problem in the past with some aftermarket oil pumps airated oil will damage the bearings. also check the oil pump drive gear for damage.
Brian
63 Plymouth Valiant Wagon
PostPosted: Sun Apr 13, 2014 10:19 am
Thanks for the feedback...
- okay - definite about torquing the flywheel - and used loctite red.
I've only done so many clutches but never forgot to do that. Also,
noise is coming from several spots in oil pan - if it was concentrated
and more toward the rear of the engine I'd think more flywheel.
- The oil pump sucking air is a new one on me - and after reading a bit
from one of the sites pointed to by a slantsix thread about how the bearings work, I'm guessing that it could cause the noise I'm hearing.
Guess you'd see some seeping of oil around where the pump mounts when it's not running?
I'll know something I hope when I get under there next - hay season and
we just had to pull it out of the building I was using - I used a small torque
wrench to do the oil pump bolts and they felt reasonably tight at that. I used red rtv on the gasket.
I like that theory the best as I guess there's always the slight chance that
a little tightening and if the damage isn't too great all might be well for a
while - but that's really just probably my wishful thinking and laziness!
A friend pointed out that with the (gritty) crud I saw in the oil pan and my assumption that the engine has 140k possibly being mistaken and it's 240k (or 340... or ... ) that the long time owner may simply have rarely changed the filter or oil for that matter. Plus, adds another mechanic, you can get great oil pressure readings with clogged channels or a spun bearing...
I'll give an update at some point. Meanwhile, here west of d.c. an hour (not too far from Winchester), I'd at least think about swapping something in it - haven't pulled too many engines (at all) - may do a yard search (Leon's just south of Culpeper is one place) and keep an eye on the for sale / trade thread here.
Meanwhile will continue reading... seeing if my buddy with a real shop
feels like having it around for a while. He didn't seem to be too interested
in the slants so...
DCello
PostPosted: Wed Apr 23, 2014 9:49 pm
well this is embarrassing - friend mechanic grilled me til I realized that,
hey, :idea: , I think (know) I rtv'd the OP gasket, got interrupted, then
rtv'd the dried rtv a bit more (thin, sure, but there you have it).
anyway, truck is moved so next on list is to pull pan and OP if
not engine to get better look.
DCello
PostPosted: Thu Apr 24, 2014 3:46 am
Online
Dcello - Check your PM's
