It is currently Fri Nov 27, 2026 8:10 am
PostPosted: Wed Apr 23, 2014 7:45 am
There are two kinds, mine came with the asymmetrical one and I had serious hesitation and lowend bog when I tried it. 1980 truck.
http://www.carburetor-parts.com/Holley- ... p_661.html
PostPosted: Wed Apr 23, 2014 8:44 am
The nice thick one! It is about 3/8" some I have seen are a full 1/2".
PostPosted: Wed Apr 23, 2014 9:47 am
What about the difference with the holes?
PostPosted: Wed Apr 23, 2014 9:57 am
Look at the bottom. I usually slot mine under the snorkel pull off to make sure it has full vacuum to run the door.
I also have a hole drilled in the heat deflector and run the thick gasket on both sides of it. That insures the door switches back and forth between hot air in the morning to cold ram air after warm up.
It helps a lot to keep the mileage up on short hops...to the store and back, (8 miles).
PostPosted: Wed Apr 23, 2014 10:05 am
thanks
you mean the deflector you fabbed up right?
PostPosted: Wed Apr 23, 2014 10:08 am
Yes, the heat deflector under the carb. You just need to match the hole in the intake manifold.
