Transmission Leaking
https://slantsix.org/forum/viewtopic.php?t=55184
Page 1 of 1
Author:  jhdeval [ Thu Apr 24, 2014 11:10 am ]
Post subject:  Transmission Leaking
What is this? This is right behind the pan and behind the speedometer pinion with the hose coming from it. It is and has been leaking but since my accident it is leaking much worse.
https://plus.google.com/u/0/photos/your ... 1373325622
Author:  Reed [ Thu Apr 24, 2014 11:22 am ]
Can't see the pictures. Sounds like maybe a cracked tailshaft housing?
Author:  mattelderca [ Thu Apr 24, 2014 11:48 am ]
Can't see pics either.
Assuming an auto trans here.
Do you mean between the speedo gear and the rear pan rail?
Not a hose but a harness, neutral / backup switch?
Or, rear of both the pan rail and speedo gear almost to the yoke?
IIRC there was an oiling mod for the rear bushing, if its a steel line it might be that?
Other than those two the only thing I can think of is a vent tube. But that might be a manual trans thing back that far.
Edit: I was thinking newer, that appears to be the park cable to me but I'll let the experts confirm.
Author:  jhdeval [ Thu Apr 24, 2014 11:52 am ]
Sorry about that. I am not sure about that because there is some silicon on the box where the hose enters.
Author:  jhdeval [ Thu Apr 24, 2014 12:32 pm ]
I am thinking maybe this?
http://www.ebay.com/itm/TORQUEFLITE-727 ... 4897.l4275
Author:  Danarchy [ Thu Apr 24, 2014 2:53 pm ]
and or speedo cable seal(o-ring?)
Author:  jhdeval [ Thu Apr 24, 2014 3:25 pm ]
I thought it might have been the speedo seal but the car has not moved and the main "puddle" is more towards the center of the car.
Author:  63dartdude [ Thu Apr 24, 2014 5:40 pm ]
I can't tell from the photo. But once I had a leak and couldn't find it. It turned out to be where the Kickdown lever was at. A total wipe down,and then see what area the leak is coming from is the best way to find out what is leaking. That is how I found out where my leak was at.
