It is currently Wed Nov 25, 2026 11:04 am
PostPosted: Thu Apr 17, 2003 7:42 pm
I just pulled the crank out, and I'm about to pull the pistons. I just don't know exactly how to do it. I wanted to ask you guys before I messed something up. Thanks.
65' Dart. A work in progress..
______________________
Joe
PostPosted: Fri Apr 18, 2003 12:42 am
if you have a large ridge at the top of the piston hole you'll need to remove it or you take the chance of breaking the piston lip. if none or very little ridge just push it out the top.
PostPosted: Fri Apr 18, 2003 2:31 pm
Thanks for the reply. I scaped away the ridge and out they came. Now it's off to the oven.
Joe
