| Engine balancing https://slantsix.org/forum/viewtopic.php?t=55211 |
| Author: | SlantSteve [ Sat Apr 26, 2014 10:00 pm ] |
| Post subject: | Engine balancing |
I'm building up a very mild street engine using a set of 198 rods and 2.2 pistons,mildly ported head with stock valve sizes, 2bbl carter,stock exhaust manifold and a regrind cam thats pretty tame,just above stock..when you guys use the 198 rod/2.2 combo do you get them balanced or just run as they come? Thanks |
| Author: | slantsik [ Sun Apr 27, 2014 4:09 am ] |
Gday Steve. I believe the crankshaft is balanced from the factory to a decent level. having all 6 rod/piston assembly all the same weight will maintain that balance. I imagine a race engine seeing 6k+ rpm would want a full balance with the bob weights etc. where did you get the bits. Imported? |
| Author: | Charrlie_S [ Sun Apr 27, 2014 5:38 am ] |
Inline six cyl engines do not use bob weights, when balancing. The crank is balanced alone. then the damper is balanced, then the flywheel/flexplate (you should be able to swap the damper, flywheel with out changing the balance). Each piston/ring is balanced to each other. Each rod is balanced big end and total weight to each other. |
| Author: | Sam Powell [ Sun Apr 27, 2014 6:07 am ] |
I did not pay to have my pistons and rods balanced, and it shakes at just a fewspecific RPMs. It is smooth at 650, but shakes a bit at 2000. I chose not to because I was not planning on spinning up high RPM, but it became clear there are other reasons to balance the rotating assembly. Sam |
| Author: | ntsqd [ Sun Apr 27, 2014 1:53 pm ] |
I have every engine that I have built balanced unless it's a seriously tight budget build in which case it's an engine that I'm not planning on keeping. Balancing is effectively free HP and can make the engine much nicer to drive no matter what it's power goals are. |
| Author: | Charrlie_S [ Sun Apr 27, 2014 3:50 pm ] |
On a mild street build, that will not see over 5,000rpm, I would rather spend the money elsewhere. Yes there is free hp, but there are others mods that give more bang for the buck. The factory crank balance is fine, and even if you change pistons/rings/rods, to units that are a different weight then stock, as long as they are the same as each other, there is no need to be any better then the stock tolerance. I would rather spend the money on dist recurve, free flowing exhaust, increasing compression, etc. I turn my race engine over 6,000rpm with factory pistons, rods, and crank. Stock factory balance. I also have a street 170 engine that was built like a race engine, but for economy (bored and honed with a block plate, decked, milled head, pocket porting, mild cam, stock 1 bbl holley, and stock exhaust manifold). This engine is balanced, even though, it will never see over 4,000 rpm. |
| Author: | sandy in BC [ Sun Apr 27, 2014 5:10 pm ] |
Im with you Charlie. I pay attention to the static balance. Its very easy to be very accurate for next to no money. ....next up is balancing combustion chamber volumes.,,,,,cuz yer rotated balance gets flustutd by unequal firing pressures. |
| Author: | SlantSteve [ Mon Apr 28, 2014 2:26 am ] |
Thanks for the replies everyone... I'll get a set of scales and do the rods and pistons...the rods were from a purchase on EBay, the seller was very careful how he worded the listing,when I got them the caps and rods weren't numbered,caps all mixed up and fitted backwards, it was quite a jigsaw puzzle. After reconditioning they came up OK,but I wouldn't like to use them in anything I would spin up high,that's why I'm using them in this mild build. Considering their unknown history a balance is probably great insurance...who knows if they were even a matched set. I'll also be matching chamber volumes and checking the bore to chamber alignment....by the way...if I shoot for a DCR around 8:1 that's fine for a street combo? Thanks again |
| Author: | ntsqd [ Mon Apr 28, 2014 7:04 am ] |
Look up the rig used to weight match the big ends of the rods. It's nothing exotic and you should be able to fangle something together at home to do the same thing. Now that the caps are best aligned and I'm assuming that the big ends got re-sized I wouldn't worry about running them in anything that they're appropriate for. Only reason for stamping them is to avoid what you just went thru to get them usable. I'd venture that with good rod bolts in them that yer good to go! |
| Author: | SlantSteve [ Mon Apr 28, 2014 12:01 pm ] |
Thanks, yep they got ARP bolts and resized. The big end bores were pretty out of round when I got them,I'm assuming they saw some good rpm at some stage of their life,but now they are all resized they should be fine,I'm just being fussy.. The other build I'm going to do is a little hotter,but I'm going to use some local Holden pistons to get a 3.5 bore with standard length rods,so the 198 rods aren't a necessity in that build anymore...long story!
