Automatic transmission ratios.
https://slantsix.org/forum/viewtopic.php?t=55218
Page 1 of 1
Author:  Sam Powell [ Sun Apr 27, 2014 6:41 pm ]
Post subject:  Automatic transmission ratios.
This is what I found on line. Are these always right, or are there variants? Is the slant 904 the same. I kind of assume they are talking V-8 here.
Transmission
Gears
1st 2nd 3rd 4th
727 2.45 1.45 1.00
904 2.70 1.54 1.00
518 2.45 1.45 1.00 0.69
500 2.74 1.54 1.00 0.69
Author:  Charrlie_S [ Mon Apr 28, 2014 4:27 am ]
If I remember correctly, the 904 had gear ratios of: 2.45-1.45-1.00 in the early years. Somewhere in the 1970's they went to the "wide" ratio low 1st gear, of: 2.74-1.54-1.00
Author:  Sam Powell [ Mon Apr 28, 2014 4:57 am ]
Thanks Charlie. I have worked up a chart on Excell that shows rpm vs speed in all gears of both versions, with the four most popular rears, and with an overdrive trans. As soon as I can figure out how to get it posted on photobucket I will post it in another new thread discussing rear end ratios.
Sam
Author:  DusterIdiot [ Mon Apr 28, 2014 5:48 am ]
Post subject:  There used to be....
There used to be a couple of nice spreadsheets floating around on one of the other mopar boards that you could plug the tranny ratios into, your rear gear ratio, your tire size...then it would spit out the rpms for you and the speedo gear tooth count as well....Pretty accurate for working up drivetrain options, the automatic chart was nice enough to calc in a factor for convertor slippage as well.
FYI.
Author:  Sam Powell [ Mon Apr 28, 2014 6:14 am ]
Thanks DI. I went ahead and worked up my own based on current performance. It did not take long. My trans has lock up Torque Convertor, which takes out the slippage issue. Although the projected mileage with the 904 OD is about 1.5 mpg lower than actual measured mileage with the old T-5 which had .79 OD as opposed to the .78 of the GV unit.
I am eager to read comments on reactions to the various ratios folks have experience with.
Sam
