It is currently Sat Nov 21, 2026 11:12 am
PostPosted: Mon Apr 28, 2014 7:49 am
I have a '64 Dart with an A904. I switched from 2.76 final gears to 3.55 in an attempt to help the car's acceleration. While it has helped somewhat, it appears that now I'm just shifting at lower speeds (probably the same engine RPM, if I had to guess). I've got the kickdown adjusted so that the lever is fully actuated at full throttle. Even at full throttle, the transmission is shifting out of 2nd gear at what I'm calculating to be around 3300 RPM, maybe a little higher depending on the amount of converter slip. I don't have a tach, so this assumes that my speedometer is correct, as well as my assumptions about the car's original gearing and tire size. (2.93 and ~185-80-13) Even if these are slightly off, the fact remains that the thing is shifting earlier than I'd like.
I'd really like the transmission to ride it out until 4000 RPM or so at full throttle, but transmissions are still kind of a black box for me. Is it a matter of increasing the line pressure, or what? This transmission was rebuilt around 2005, and while I don't know exactly what work was done, it shifts firmly, almost like it has a shift kit already.
Escape Velocity Racing
PostPosted: Mon Apr 28, 2014 9:02 am
The valve body is a hydraulic computer. Generally speaking, upshifts happen when the throttle pressure is exceeded by the governor pressure. To reduce governor pressure and delay upshifts you want lighter governor weights. A&A Transmission and others have the weights. There are many articles on-line about increasing the road speed at which shifts occur.
PostPosted: Mon Apr 28, 2014 12:08 pm
I think stock shift point is 4000 rpm for a 904; that is where mine shifts once warmed up. If it is shifting early than the kick linkage down may not be adjusted correctly. Or, carburetor is not fully opening throttle plates because of incorrect throttle cable adjustment which would limit kick down travel, or accelerator pedal is hanging up on carpet not getting enough travel to fully open up throttle plates and retracting throttle pressure lever (kick-down) fully.
If you want higher rpm shift point, than change governor weights in tail shaft as Josh mentioned.
The other situation that may be happening is with the lower gearing engine is not working as hard, and if foot has not fully mashed the accelerator to floor the transmission will shift early because it thinks the throttle pressure has dropped off signaling up shift time.
With my car if higher shift point is needed say when racing I just shift it manually.
PostPosted: Mon Apr 28, 2014 3:02 pm
How is your 1st to 2nd shift point? Do you want that shift point higher also?
A gov. weight chnage will change both shift points.
You may have to change shift valve spring tension, if one shift point is where you like it, but the other is not.
PostPosted: Mon Apr 28, 2014 3:58 pm
I'm pretty sure my kickdown is fully actuating, because when I tried to extend the rod linkage further, it started limiting my pedal travel. Still, it would be a good idea to get under the car and verify the movement of the lever with someone else pushing the pedal down. I'll try to do that tonight.
Doc: at full throttle, I am shifting into 2nd at an indicated 28 mph, and into 3rd at an indicated 55 mph. My tires and rear gear are not stock, but if my speedometer was correctly calibrated to what I assume the original tires and rear gear were, then this corresponds to a real-world speed of 23.4 and 46 mph, respectively. That means that I shift into 2nd at 2740 RPM and into 3rd at 3186 RPM, before considering torque converter slip. I don't mind the 1-2 shift being a little lower (is this normal?), but I would like to raise both shift points substantially.
Otherwise, the transmission seems healthy. It shifts firmly, at least. It has a slow leak from the melted shift cable jacket, but we keep it topped off during races.
PostPosted: Mon Apr 28, 2014 4:08 pm
Too Lazy to replace the cable huh? :lol:
1964 Dart GT
PostPosted: Mon Apr 28, 2014 4:41 pm
... or "patch" the burt section with a slit piece of rubber fuel line hose, RTV and a few small hose clamps... (clean it before appling the RTV) :wink: :roll:
PostPosted: Mon Apr 28, 2014 5:11 pm
This.......
I have to (eventually) adjust the valve spring tension for the 1-2 shift.
My 1-2 shift is at about 3000 rpm, the 2-3 at about 4000 rpm (which I think is perfect).
The valve springs are probably easier to get too........
PostPosted: Mon Apr 28, 2014 9:44 pm
Haha, no, it's on the agenda. Just haven't gotten to it yet. Our next race is in July, and personal car issues have been taking up all the team's spare time. Just figured I'd mention that as a recent issue in case it mattered. I don't now if there's any way we might have damaged something by accidentally running it low. We have applied the slit hose full of RTV, which is why we only go through about half a quart in a full day of racing now. The cable had a pretty large wound in it, and I guess the RTV coverage was less than stellar.
I did get under the car tonight and verify that the lever on the trans is in fact pushed as far as it can go when the throttle is pushed to the floor. I guess we'll have to get busy with governor weights then. I'm just wondering why it's like this in the first place. Is this about where the shift points would be when the transmission was stock?
PostPosted: Tue Apr 29, 2014 9:39 pm
A Trans-go TF-2 reprogramming kit will help. If you install the "shift command" option you can hold it in any gear as long as you want. It was the biggest improvement we did on our Duster,
