904 stall Converters
https://slantsix.org/forum/viewtopic.php?t=55229
Page 1 of 1
Author:  Mr Zeal [ Tue Apr 29, 2014 5:37 pm ]
Post subject:  904 stall Converters
Is the same TC used for a /6 904 as a sb904? Please explain "lock up" and "non-lock up".
Author:  wjajr [ Wed Apr 30, 2014 5:55 am ]
Torque converter is a torque multiplying device that relies on a rotating fan like set of blades that force fluid through a stationary set of similar blades attached to transmission. By forcing fluid through the stationary blades the transmission has rotational force applied to its input shaft. There is no mechanical connecting engine to transmission. The amount of rotational slippage between engine and transmission can be varied by pitch, and number of blades and vanes which in turn governs stall rpm (rotational speed that torque converter’s engine driven blades rotate at same rpm as transmission input shaft.
Lockup:
Later transmissions were redesigned for better fuel economy by using a torque converter that under certain conditions would stop being a viscous coupling between engine & transmission and would “lock upâ€￾ forming a direct mechanical connection between engine and transmission via a third band all controlled by a lockup valve body. This lockup is controlled by rpm, engine load, and would be applied automatically once car’s velocity exceeded 40 to 45 mph under light engine load in third gear. It wasn’t until computer controlled transmissions came along that this technology really worked smoothly.
Author:  DusterIdiot [ Wed Apr 30, 2014 5:01 pm ]
Post subject:  Yes...
Yes, they plug and play, but the V8 convertor may not have the same stall rating as the /6 version.
Author:  Mr Zeal [ Wed Apr 30, 2014 6:23 pm ]
Good to know. So if I pick up a 904 TCI converter with, say, 1800-2200 stall it might do...what?
Author:  Fopar [ Wed Apr 30, 2014 8:12 pm ]
It will be more like a stock converter.
Richard
Author:  Mr Zeal [ Wed Apr 30, 2014 8:30 pm ]
OKay then. So if I am building a semi-rumpity /6 with around 225 HP, what TC would I want with 3.55 gears? Affordable is a must. Can't go $500 for a TC.
Author:  slantzilla [ Thu May 01, 2014 3:22 am ]
You will want at least a 3000 stall, more would be a little better.
You can have Midwest or Edge build you one for $350ish.
Torque converter is one area where you definitely get what you pay for.
TCI=Total Crap Inside.
Author:  wjajr [ Thu May 01, 2014 5:31 am ]
You need to find or figure out what your engine’s torque curve looks like to determined what stall is needed. Or let a converter company design one for you based on cam card, engine build, rear gear, and rear tire size.
As stated above V8 stall numbers are higher than what that same converter would stall at behind a six cylinder’s lower torque output. The other concern is the higher stall converter is tight enough to be stalled up in the rpm range you cruse at if this car is used as a driver. If the converter is not stalled up most of the time one is cruising it will develop excess heat possibly damaging transmission, and cause fuel consumption to decrease. It is all a big trade-off particularly if car is a street/strip machine. As stated above, don’t skimp/cheap out, or you will end up with a converter that won’t do a good job on the street or strip, and the filling station guy will love you. Keep in mind that all listed stall speeds are for V8’s.
Author:  Mr Zeal [ Thu May 01, 2014 5:54 pm ]
OK, now I am completely confuzzled. If I have to worry so much about the converter being too tight off the line, why do I need to be concerned about it being too loose when cruising?
Semi- rough idle cam, shaved head, roughly 200HP, 3.55 gears, 25.5 inch tires. What converter should I run for street/strip?
Author:  slantzilla [ Thu May 01, 2014 11:38 pm ]
Contrary to the popular belief, a high stall converter will work like a normal converter under cruising condition. It will only flare when it has power applied to it.
Simply put, most of the time you won't even know it is there.
Author:  Mr Zeal [ Fri May 02, 2014 6:31 am ]
Thanks, Zilla. That is what I was wondering. 3000 Stall for street/strip then?
Author:  wjajr [ Fri May 02, 2014 7:16 am ]
True
However more expensive better designed torque converters are better able to cruse with less slippage with a high stall rating; more streetable one might say. The chepo converters are well, sloppy, and aren't as efficient. You get what you pay for.
Author:  slantzilla [ Fri May 02, 2014 8:07 am ]
I've heard that before somewhere. :D
Author:  Greg Ondayko [ Fri May 02, 2014 5:28 pm ]
:D :D :P :lol:
Author:  Dart270 [ Sat May 03, 2014 10:30 am ]
I'll say it again: Do not skimp on the converter price. Save up and spend $400 to get one from Midwest or Edge. Yes, an efficient converter will act like stock until you lean on it, then you will have power applied at a higher RPM where you can really use it. Make sure you get a 9.5" (or between 9-10") converter size for street/strip, and not 10.5-11".
