How to replace a sure grip in an 8.75 rearend?
https://slantsix.org/forum/viewtopic.php?t=55233
Author:  bmimken [ Wed Apr 30, 2014 6:14 am ]
Post subject:  How to replace a sure grip in an 8.75 rearend?
I have an A-body 8.75 rearend with 3.23 gears in a 489 case with sure grip. I am assuming the sure grip has either failed or worn out, due to the rear now spinning only one wheel. No unusual noises noted, or vibrations. I have not pulled the center section yet.
After I pull the center section, and determine whether it has the clutch or cone style sure grip, can I simply swap out the sure grip for a new unit without disassembling the center section and having to reset the backlash on the pinion and ring gears?
Any other advice is appreciated as well. I don't know what I don't know. :wink:
Brian
Author:  Exner Geek [ Wed Apr 30, 2014 7:55 am ]
Changing the differential itself does not require having to adjust the depth of the pinion gear which is a complicated procedure you want to avoid. Once you bolt the ring gear to the new differential (Left hand threads there) you can just drop it in and then you adjust the backlash by moving the ring gear with the bearing adjusters. You measure the backlash with a dial indicator contacting the ring gear tooth. Find the right spec, it is really quite easy to do.
There might be some bearing interchange issues with a differential out of a 741-2 carrier (check on this) but they are basically interchangeable. Good luck Brian.
Author:  Rick Covalt [ Wed Apr 30, 2014 1:03 pm ]
It is not really hard at all. If I can do it you know it ain't none to complicated!! :lol: :lol:
PS. If it turns out that it is the cone type and you are going to replace it let me know. Ryan may be interested in buying some parts out of your old unit if you want to sell them. He broke the spider gears in his but the cone style posi was still working good.
Rick
Author:  bmimken [ Thu May 01, 2014 7:55 pm ]
Thanks Seymour!
Rick, I will keep that in mind. Might get to it next week.
Brian
Author:  Charrlie_S [ Fri May 02, 2014 3:55 am ]
My suggestion, is to measure the backlash, before taking the carrier out of the pumpkin. Then set the backlash to the same number, when reinstalling, the new carrier. That will reduce the chance of the rear being noisy.
Author:  Dart270 [ Sat May 03, 2014 10:31 am ]
Ditto what Charlie said. That is the key measurement needed for reassembly.
