Passing DEQ and New Cat Options
https://slantsix.org/forum/viewtopic.php?t=55238
Author:  nicholas482109 [ Thu May 01, 2014 8:28 am ]
Post subject:  Passing DEQ and New Cat Options
Hey everyone, it's been a while since I posted on here.
I've been struggling to get my 78 Aspen to pass emissions in Oregon (DEQ). When I first went I failed with 6% CO. I went again yesterday after changing the oil, spark plugs and air filter. I also turned the idle mixture screws in a quarter turn. I failed again but with 4% CO then the second run after the operator ran it on high rpm for a few seconds it was at about 2%. Both of these runs on my second try also failed HC while it passed the first time I went to DEQ.
My plan now is swap out the carburetors for a '77 318 BBD. I know the carb on the car now that was on it when I bought the car now is for a '78 slant 6 truck. The idle circuit also seems to be ruined since it won't idle under 1000 rpm. The 318 BBD I have can idle much lower fine. I was hoping to swap them out tonight and go DEQ after work on Friday.
Do you guys have any tips for me? I keep my timing at 12-14 BTC, the hood sticker says 12 BTC +/- 2.
If the carb swap doesn't pass it what else can I do? HEI? New cat converter? I've read on here that the these cars need a certain type of cat, could someone help me find a new one to buy?
Sorry for the long post and thanks for any help.
Author:  Reed [ Thu May 01, 2014 10:33 am ]
I would find out why the engine won't idle below 1000 RPM. You may have a problem external to the carb that swapping the carb won't fix.
Start by checking for vacuum leaks and checking that the throttle linkage has enough slack for the throttle to close completely.
Have you adjusted the metering rods on the carb (I am assuming the current carb is a BBD)?
You might very well have a failed and clogged catalytic converter. Three-way high flow cats are what I would use. If your car has an AIR injection system, make sure is it operational and connected correctly.
HEI would help a little.
Do yo have a clean air filter? PCV? Crankcase breather?
Author:  nicholas482109 [ Thu May 01, 2014 10:57 am ]
When I've used the 318 carb that I want to put on, it did idle properly. I swapped it out during the winter because I thought it was making my engine die when I turned the steering wheel to the max w/ power steering. I could have probably just adjusted the idle or let it warm up more.
When I put the current carb back on, I checked for vacuum leaks. I had sanded the faces of the different castings of both carbs when I last rebuilt them which helped eliminate leaks. I did the rebuilt by the books and double checked each adjustment and spacing. I have the proper choke lever adapter for the 318 BBD as well.
What metering rod adjustment are you talking about? the screw on top of the piston when you remove the small plate on top of the carb?
When I did some exhaust work in august I took out the cat and it didn't look or smell wrecked. Nothing fell out and nothing seemed burnt.
no AIR pump
I replaced the breather and PCV when I bought the car 13 months ago, the PCV valve still rattles. I have an air/oil separator installed too. I replaced the air filter on Tuesday, less than 24 hours before the test on Wednesday.
I think this cat fits the bill. I'll have to take measurements to be sure.
Author:  Reed [ Thu May 01, 2014 12:20 pm ]
Metering Rod Adjustments
Are you 100% certain that you used the correct gaskets when you rebuilt the carb? Have you verified that the vacuum choke pulloff diaphragm holds a vacuum and doesn't leak?
Your cat may have failed internally and melted down. I had it happen to a cat I installed on my brother's 83 Dodge van.
The cat you found looks OK, but a bit pricey. I usually use CatCon converters (high flow three way). You really don't need a polished case on a catalytic, unles you really want it. It will likely discolor and rust anyway after a few hundred heat cycles.
Author:  nicholas482109 [ Thu May 01, 2014 1:16 pm ]
Yup, I did all of those adjustments. That looks just like the page that came in the rebuild kit. I am sure I used the correct gaskets and I have verified that the choke pull off diaphragm holds a vacuum pressure and does not leak. It may leak very slowly but holds pressure according to the tolerance in the FSM. I will verify these things when I get the carb together tonight for the swap.
I definitely do not care about the polished look at all. Do you have a place you like to get your CatCo products from. I would need to get it shipped to me quickly and wouldn't mind paying for 1 day shipping if I need to and the site allows it.
Almost forgot to say thanks, Reed. You've helped me out before too.
Author:  kesteb [ Thu May 01, 2014 8:59 pm ]
I think a better question is why is Oregon trying to force a 38 year old car thru emissions, and when can you by pass this by paying a fine or paying a mechanic X amount of dollars to "fix" the problem.
Author:  Mr Zeal [ Thu May 01, 2014 9:24 pm ]
I am having the exact same problem with my 77 Volare, also in Portland. Just rebuilt the carb and get black smoke every time I rev the motor ( same as before I kitted it), as well as flat spots. I admit that I am a newbie when it comes to trying to adjusting a BBD 2BBL.
Why does Portlandia insist on making 38 year old cars pass emissions? Because they want old cars to go away in the name of "green-ness". Dumbest city I have ever lived in. So liberal that it makes Frisco jealous.
And no, mechanics cannot "fix" the problem ( if I get your drift) like in California because it has to go through the government-run test station, and yes, ALL of your original smoggies must be in place. So no cheating. Heck, in Portland you can have a perfectly clean running car and fail "emissions" because of stored inactive code in your ECM. I kid you not.
Author:  Reed [ Thu May 01, 2014 10:42 pm ]
Ebay, summit, jegs, maybe rockauto. A working AIR pump with direct injection into the cat can really clean up the exhaust. I had to get my brother's 83 Dodge van to pass emissions one time. I had no visual to pass, just a sniffer. The van has a two barrel carb. The van failed until I installed a cat and an air pump. Then it passed with flying colors.
However, the cat melted down and failed internally about a year later and totally clogged the exhaust. The problem is that carbs can't control the fuel mix tightly enough and will pass too much fuel into the catalytic which causes it to overheat and melt down.
Now that the van no longer has to pass a sniff test, all the emissions stuff has fallen off. However, I have had several exhaust shops refuse to work on it because it is supposed to have the dual mini-ox cats.
Modify at your own risk.
Author:  DusterIdiot [ Fri May 02, 2014 6:05 am ]
Post subject:  Hobby and lobby...
Oregon DEQ is an old law, and was supposed to be adopted through out he state, instead testing is only enforced in high smog areas like Portland and Medford...The law states that pre-1975 cars are exempt because there are very few left on the road, and yet there is no rolling exemption for cars in the 1975-1980 range that require an idle sniff test (which there should be a rolling exemption since the only real change between a 1974 and a 1976 duster is the cat convertor and the rarity/amount made). Here mechanics plug and play parts and you pay until you pass the test.
The other issue is that there is no fine, they just won't let you get new tags and renew your registration on the car, so it effectively is taken off the street (or risk it being impounded and you get fined, and court, and if the car is worth less than the fees owners typically abandon it at that point...)
Another political problem exists that you can be smog exempt in Portland and live there if your car registration has an address out of the city/county....so DMV has on the books over 1 million vehicles that require smog that are registered to my city down south that does not require testing (yet), but we only have a population of 130,000...(10 cars per person..I gotta get 7 more!)
Because of this loophole and residents having their car registered at their buddy or relatives house here, the car lobby had not pressured the legislators to provide for a rolling exemption like california has (they used to be 25 years I think, but have the "buy back and junk it law"). I figure at sometime in the near future (the government had talked about it starting in 2020), all counties are to test per the law, sadly until then/when panic sets in someone won't pony up and lead the charge to get the signatures to get the law changed.
This is one of the prime reason I live in my area, I don't have to smog my 1976 Dusters.
FYI.
Author:  Mr Zeal [ Fri May 02, 2014 6:44 am ]
DI, as I understand it, Medford's cut-off date is different from Portland's, and is a rolling date. Oklahoma City used to have similar testing, but got rid of it when cars got cleaner and the vast majority sailed through DEQ on tailpipe emissions without a problem, making the program obsolete in the eyes of the citizenry. So when it came time to spend the money to update the equipment to check ECMs they decided not to fund the upgrades.
Even here in Portland the number that fail is quite low, and as I said, many of those are for reasons that have nothing to do with tailpipe emissions. It took three weeks to track down a tiny intermittent vacuum leak in my evaporation system on my Durango that would send a code once every couple hundred miles. it was not a tail pipe emission that failed my rig, but the code alone. As I understand from a worker at the Sherwood station, the majority of failures are accounted for by check engine lights and not emissions.
Please, someone bring back common sense!
Thus endeth the rant.
Author:  nicholas482109 [ Fri May 02, 2014 7:21 am ]
It doesn't make sense to me either. Portland is just, umm, special.
This is what happened to me, pulled over because I wasn't driving fast enough for the officer I guess. Portland cops almost never pull people over because of tags. I need to show updated registration at my court date May 9th to get the fines thrown out.
I did the carb swap successfully last night and ready to try again. This morning the car kept wanting to quit on me when I have it gave gas and it was not totally warmed up. I had to ease it up to 40. What adjustment could be causing that? Driving it warmed up last night gave no issues.
If it fails again then cat and air pump I guess. Although it looks like a pain in the ass to install.
Author:  Reed [ Fri May 02, 2014 7:48 am ]
Soudns like either (a) a choke adjustment or (b) a fuel pump shot. But I am leaning more towards the choke adjustment.
Adding an AIR pump is actually fairly easy. When I installed it on my brother's van I plumbed the pump output directly into the catalytic converter and didn't install any of the hardware to make it switch between upstream injection and downstream. The diverter valve i was using defaulted to downstream injection so the pump just constantly pump oxygen into the catalytic. Most of the time the system works in downstream injection anyway and the ports in the cylinder head are more likely than not clogged with carbon by now anyway (if your head has the air injection ports).
Author:  nicholas482109 [ Fri May 02, 2014 8:10 am ]
I was about to say that I did all the choke adjustments according to spec but it must be the way that the automatic choke thermostat is connected. I used a the small plate modification to get the choke lever to attach properly since it's a 318 BBD but maybe it's not angled quite right or the hole is binding the lever from working properly. I'll have to inspect.
What does the air pump do exactly and how is it powered? I'll need to reed up on the FSM about it more seeing as I don't really understand
Author:  Reed [ Fri May 02, 2014 8:48 am ]
The air pump is exactly that- an air pump. It is a small (17 cubic inch, if I remember correctly) belt driven pump that, depending on the emissions package, either pumps air directly into the exhaust manifold, cylinder head, exhaust pipe upstream of the catalytic converter, or directly into the catalytic converter. It has a minimal horsepower draw (you won't even notice it) but can really help to clean up the exhaust.
Think of it like a power steering pump but for air instead of hydraulic fluid.
The complexity of the air injection system cam from Chrysler's attempts to use mechanical sensors to control whether the air pump injected the air upstream or downstream or simply vented the air to the atmosphere depending on the operating conditions of the motor. This was all done in later motors by the computer controlling various solenoids. Chrysler's method worked but it created the horrible mess of hoses and evices that most hot rodders remove because they don't understand it and don't want to have it in the way of working on the motor.
You can set your system up like I did and have the air pump inject directly into the catalytic. This is where the air goes most of the time anyway. It is only on cold startups or other limited situations where the air would be directed somewhere other than the catalytic.
Your best option is to get a factory service manual for a early 80s M body and see how Chrysler plumbed the air pump and read about how the system worked.
