| Heat treated https://slantsix.org/forum/viewtopic.php?t=55255 |
| Author: | 1930 [ Sat May 03, 2014 5:25 am ] |
| Post subject: | Heat treated |
Im prob. going to send a cam to Oregon cams to have a re-grind. I thought though that the original grinds would have been heat treated for hardness, Im assuming Oregon cams cannot do this process so am I looking at a faster wearing cam? Also I have a cam in my truck now that is new but is possibly a P.O.S made from who knows where, would I be better off sending an original 1980s cam to them to have them re-grind. I am concerned with metal content, I know that by the 80s metal was already pretty contaminated but its still got to be better than what they are producing today? Opinions? |
| Author: | ValiantBoyWonder [ Sat May 03, 2014 9:54 am ] |
I believe the term you're looking for is parkerizing. http://en.m.wikipedia.org/wiki/Parkerizing I work for a guy who did alot of racing up until 90s and would have cams that were not parkerize wipe out fast. |
| Author: | 1930 [ Sat May 03, 2014 11:46 am ] |
Quote: I believe the term you're looking for is parkerizing.
Ok now t find out what Oregon covers, thanks, I know guys here have had work done thru them so hopefully they will chime in
| Author: | DusterIdiot [ Sat May 03, 2014 12:00 pm ] |
| Post subject: | Yep... |
I have had 5 cams ground by them and currently have used 3, no problems on run in and driving/racing. The add a coating to the cam after grinding that looks like parkerizing. my 2 cents. |
| Author: | Rick Covalt [ Sat May 03, 2014 12:16 pm ] |
Quote: would I be better off sending an original 1980s cam
A cam from the early 70-'s may be an even better choice. I have seen 3 80's truck cams that have had the oil pump/ cam gear totally wiped out.If you find a cam that is not worn after 100,000 miles, I would not be afraid to send it for a regrind no matter what year it is. And I would reuse the matching oil pump gear that it ran with. 2 more cents! |
| Author: | 1930 [ Sat May 03, 2014 1:37 pm ] |
| Post subject: | Re: Yep... |
Quote: I have had 5 cams ground by them and currently have used 3, no problems on run in and driving/racing. The add a coating to the cam after grinding that looks like parkerizing.
Thanks I will call them and continue asking around/surfing the web and will let you know what I come up with.
my 2 cents. |
| Author: | 1930 [ Sat May 03, 2014 1:39 pm ] |
| Author: | DusterIdiot [ Sat May 03, 2014 3:55 pm ] |
| Post subject: | Yes but.. |
Quote: would that still be an ok cam to use in a Hyd. engine.
You will have to pay a little extra to have them groove the rear journal for oil flow like the 1981-1987 cam blanks.
| Author: | 1930 [ Sat May 03, 2014 5:05 pm ] |
| Post subject: | Re: Yes but.. |
Quote: Quote: would that still be an ok cam to use in a Hyd. engine.
You will have to pay a little extra to have them groove the rear journal for oil flow like the 1981-1987 cam blanks. |
