| Carter BBD questions https://slantsix.org/forum/viewtopic.php?t=55258 |
Page 1 of 4 |
| Author: | 1930 [ Sat May 03, 2014 6:17 pm ] |
Here the metal tag which came off the carb who has the screw lying next to it in the above photo. It reads 8137s and then 3277 819
| Author: | 1930 [ Sun May 04, 2014 3:58 am ] |
I was curious what BBD and BBS stood for..........Ball & Ball Dual Barrel.......(Ball & Ball Single Barrel........... Carter Carburetor was established in 1909, and lived through 1985 |
| Author: | olafla [ Sun May 04, 2014 7:41 pm ] |
Hi 1930. If you go to the FAQ in the engine section, open the link Carburetor operation & repair information, you'll find the link to the Carter BBD operation and repair manual. From page 26->on in that manual, the differences between the 318 BBDs and the new for '77 SuperSix BBD are described in detail. If you open the link to the Carter carb manuals with jet and metering rod sizes in the engine FAQ, and open and browse the Chrysler_Carter_Carb_Manuals_65to79.pdf, you'll find the numbers for the Carter carbs. They are not always placed in logical order, so you may have to 'leaf' through some pages until you find your tag number. The same engine FAQ also lists a Chrysler service training video for the new BBD for the SuperSix engines. Olaf |
| Author: | 1930 [ Mon May 05, 2014 3:06 am ] |
Quote: Hi 1930.
Thank you Olaf. I plan to print out the Carter manual but I was going to ask before doing so if that particular manual was the closest version I could get to my own particular carb. If you go to the FAQ in the engine section, open the link Carburetor operation & repair information, you'll find the link to the Carter BBD operation and repair manual. From page 26->on in that manual, the differences between the 318 BBDs and the new for '77 SuperSix BBD are described in detail. If you open the link to the Carter carb manuals with jet and metering rod sizes in the engine FAQ, and open and browse the Chrysler_Carter_Carb_Manuals_65to79.pdf, you'll find the numbers for the Carter carbs. They are not always placed in logical order, so you may have to 'leaf' through some pages until you find your tag number. The same engine FAQ also lists a Chrysler service training video for the new BBD for the SuperSix engines. Olaf I learned with the 1945 I had previously that there were many different versions and so much of the material I was able to save and print did not pertain to my own carb. Ive tried to view the video but cant get it to open on my comp. I still need to try and open it on my wifes computer. |
| Author: | Rug_Trucker [ Wed May 07, 2014 1:57 am ] |
Bent PCV fitting=slant Also the air horn is thicker on the flat side than a 318 carb. Good score! Did you snag the intakes? |
| Author: | 1930 [ Wed May 07, 2014 3:16 am ] |
Quote: Bent PCV fitting=slant Also the air horn is thicker on the flat side than a 318 carb.
Yes I did, would you happen to know where I can get specific specific information concerning how the carb was originally set-up internally? Id guess that info might be found in a factory service manual but at this point thats only a guess.
| Author: | Rug_Trucker [ Wed May 07, 2014 9:03 am ] |
A rebuild kit will have all the specs. All the ones I have didn't come with the tags. Lucky you! More than likely the top is warped. Mine get a ride on the stationary belt sander. The throttle shaft will probably need to be bushed. |
| Author: | Reed [ Wed May 07, 2014 9:27 am ] |
I think he is looking for the internal technical specs, like step up spring tension rating, manual vs. auto transmission, jet sizes, metering rod diameters, etc…. For those numbers you need a Carter carb book that lists the specs for each list number. I have one of those books for Holley carbs, but not for Carters. |
| Author: | Rug_Trucker [ Wed May 07, 2014 10:42 am ] |
I have the Dave Emanuel Carter book. That stuff isn't in there. |
| Author: | Reed [ Wed May 07, 2014 11:46 am ] |
Quote: I have the Dave Emanuel Carter book. That stuff isn't in there.
Me, too, and ditto.
| Author: | oldskoolracer [ Wed May 07, 2014 1:12 pm ] |
Theres been a couple links posted in a thread that I started about a week ago titled "timing chain?".... matv91 posted them, doesnt get specific on what spring/rod/jet combos came in wich vehicles (im assuming because the variations could be endless depending on climate, elevation, vehicle weight, gearing, trans, etc...) but does list sizes and numbers... Also due to the differences in fuel today vs fuels of yesterday, experimenting with different combos may be very useful rather than try to mimick what chrysler did 30+ years ago... He helped me realize that my carb (reman with out a tag) is a 78-79 with a set up for a manual trans cars, but with a heavier spring under the step-up piston and accel pump the carb now responds very well to my wagon with an auto trans and tall gears... Just food for thought! |
| Author: | olafla [ Wed May 07, 2014 3:17 pm ] |
Quote: For those numbers you need a Carter carb book that lists the specs for each list number. I have one of those books for Holley carbs, but not for Carters.
Hey Reed, I thought you was familiar with the engine FAQ! Look up Carter carb manuals with jet and metering rod sizes which leads you to: Chrysler_Carter_Carb_Manuals_65to79.pdf There you'll find a detailed parts list for each Carter used on Mopars from '65 to '79, and the corresponding carb model number for each year and type of engine, according to the attached tag. From the parts numbers, you can also determine which model number that should have been on the missing tag. The title 'manual' is a bit misleading, it should really read 'parts list'. There are no drawings, only text. The engines and years are not necessarily in the order you may expect, so you may have to leaf through a lot of pages to find 'your' carb/engine combo. A similar parts list for Carter carbs used in non-auto Mopar engine applications, is also linked to in the same place. Olaf |
| Author: | oldskoolracer [ Wed May 07, 2014 4:22 pm ] |
Quote: Quote: For those numbers you need a Carter carb book that lists the specs for each list number. I have one of those books for Holley carbs, but not for Carters.
| Page 1 of 4 | All times are UTC-08:00 |
