| valve lash too loose https://slantsix.org/forum/viewtopic.php?t=55260 |
| Author: | killnine [ Sat May 03, 2014 9:41 pm ] |
| Post subject: | valve lash too loose |
I finally got the duster driving, but now that it's on the road I think the valve train noise is abnormal. At first I just thought it was the normal sewing machine noise everyone says a slant sounds like, but now I'm thinking I might have set the lash too loose on the exhaust or something. Here's a video with me getting on and off the gas. It's mostly noticeable above 1000 rpm or so. Especially under load, but even in neutral when revving. http://youtu.be/AMQx_T0JSJ4 Thoughts? I've got another 7 hours left to get her home tomorrow. |
| Author: | emsvitil [ Sat May 03, 2014 9:51 pm ] |
Sounds like an exhaust leak to me |
| Author: | slantin_77 [ Sat May 03, 2014 10:29 pm ] |
Agreed...check the manifold and the manifold flange where the downpipe bolts up to. Mine in my '77 D100 has a bolt that snapped in half and the downpipe got cocked to the side, and makes a similar sound but not as loud. It definitely sounds exhaust-related though. |
| Author: | killnine [ Sun May 04, 2014 6:09 am ] |
Will do. Loose valves or exhaust I think it's safe to get home without any engine damage. Things will be much easier to fix when I'm home. Thanks guys |
| Author: | mopardean [ Mon May 05, 2014 5:39 am ] |
one trick i have used to confirm exhaust manifold leaks is to pour a little sea foam down the carb throat. a puff of black smoke will quickly confirm the location of the leak |
| Author: | Aggressive Ted [ Tue May 06, 2014 5:52 pm ] |
Sounds like the head pipe joint is leaking.....use a Remflex at that joint. |
