It is currently Sat Nov 28, 2026 5:43 am
 Post subject: holley 1 bbl question
PostPosted: Wed Mar 12, 2014 10:03 am
i have several skant carbs, don't have anything to tell about the numbers but the rebuilt carb on my 76 has fuel inlet on front of carb and all others on side, is this a correct / carb or just what they came out with later like 76 or is it a truck carb or what????? inquiring minds want to know ???? thanks
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Wed Mar 12, 2014 10:39 am
None of the one barrel 1920 or 1945 Holley's came out the front, only on the side....
Carter one barrels come out the front.......
As a side note......
Two barrel carbs.......BBD Carters and Holley 2280's came out the front.
 Post subject: carb?
PostPosted: Wed Mar 12, 2014 1:15 pm
i have a carter 2 barrel sittin on shelf that clearly says carter, this carb in question is 1 bbl, can
t find any name on it... remaned by autoline out of canada.... has these no on pass side: 4006603, below that, 7357 and 0856 to the right of that is 6R-5147B
i ran this carb all last summer and fall 65 mi a day, runs great, wanted to put it on another car i w ill drive and didn't want to fool with cleaning and carb kit on the holley right now. i'm just curious what it is! ??
last spring when i picked up this car the holley on it clearly neeeded a kit, had neighbor tractor mechanic put a kit in it and it wouldn't run for squat so i ordered a rebuilt carb and this one is what they sent. everyone says don't order a remaned carb but maybe i got luckly but what is the sucker!!?????
 Post subject: It's...
PostPosted: Wed Mar 12, 2014 6:16 pm
Holley 1945 P/N 40066003 Manufacturer number R-7357-A For all car lines (including B-body) with 225, Automatic, without california emissions package...
 Post subject: carb
PostPosted: Wed Mar 12, 2014 7:55 pm
i thought those were maybe Holley numbers but maybe the fuel inlet being in front of carb is later model? DIDN'T KNOW IF ANY OF THOSE NUMBERS WERE DATES. anyway it runs good. thanks for the info.
 Post subject: H1 1945 ?
PostPosted: Mon May 05, 2014 2:44 am
I'm glad Barbee got his Carb identified(that's cool). Will you guys please tell me if this a Holley 1945 too ?
Because the gas inlet is on the front & the numbers are a lil different than Barbee's & frankly I'm lost.
6R (5147)B (G) 4006603 7357 1336
 Post subject: carb
PostPosted: Mon May 05, 2014 6:05 am
thanks for the info.....I traded off the feather duster to friend for 65 273 cuda project...... no interest from anyone on buying it.. I like the early A's best and have several of those in slant form.
 Post subject: Yep...
PostPosted: Mon May 05, 2014 6:35 am
Holley 1945 was used in 1974 and forward model year cars the part numbers typically higher than 375XXXX are 1974+ year parts (or an updated part number for the part if they changed it a little).
Mopar part number corresponding to a 1976 Holley 1945 for all car platforms with 225 and automatic transmission without california emissions package
PostPosted: Mon May 05, 2014 9:24 am
Thank you
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
