| 1962 Valiant - how to attach a door check/strap https://slantsix.org/forum/viewtopic.php?t=55290 |
| Author: | crickhollow [ Wed May 07, 2014 3:58 am ] |
| Post subject: | 1962 Valiant - how to attach a door check/strap |
What is the best 'fix' to attached the door strap to the car pillar? I see on ebay an item called Door Limiting Arm Rivet Kit, it looks like a good part to use. Feedback sought please! Thanks, Peter |
| Author: | hyper_pak [ Sun May 11, 2014 7:30 am ] |
| Post subject: | door rivets |
yes you can use these. I bought a similar part a few years ago. these are from an office supply company used to screw document packages together! the problem is there are a ton of sizes, and lengths so if you go get them yourself you have to find the right one and then buy 100! if this guy has the right ones its a good solution to the door jam. let us know how these work for you. |
| Author: | crickhollow [ Mon May 19, 2014 3:31 am ] |
Hi, thanks for the info. I now remember that I used a similar part years ago when I worked in an office; we used these for binding our documents into books/folders. I will get back if I locate same. |
