It is currently Sat Nov 28, 2026 1:07 pm
 Post subject: valve lash too loose
PostPosted: Sat May 03, 2014 9:41 pm
I finally got the duster driving, but now that it's on the road I think the valve train noise is abnormal. At first I just thought it was the normal sewing machine noise everyone says a slant sounds like, but now I'm thinking I might have set the lash too loose on the exhaust or something. Here's a video with me getting on and off the gas. It's mostly noticeable above 1000 rpm or so. Especially under load, but even in neutral when revving.
http://youtu.be/AMQx_T0JSJ4
Thoughts? I've got another 7 hours left to get her home tomorrow.
1970 Plymouth Duster, 198 Slant Six, Super Six setup w/ EI conversion
http://www.semisynthetic.net/kill-9/gal ... p?album=34
PostPosted: Sat May 03, 2014 9:51 pm
Sounds like an exhaust leak to me
PostPosted: Sat May 03, 2014 10:29 pm
Agreed...check the manifold and the manifold flange where the downpipe bolts up to. Mine in my '77 D100 has a bolt that snapped in half and the downpipe got cocked to the side, and makes a similar sound but not as loud. It definitely sounds exhaust-related though.
-Brodie
1977 Dodge D100 stepside, slant six/3 on the tree
2002 Chrysler 300M Special (daily driver)
PostPosted: Sun May 04, 2014 6:09 am
Will do. Loose valves or exhaust I think it's safe to get home without any engine damage. Things will be much easier to fix when I'm home. Thanks guys
PostPosted: Mon May 05, 2014 5:39 am
one trick i have used to confirm exhaust manifold leaks is to pour a little sea foam down the carb throat. a puff of black smoke will quickly confirm the location of the leak
PostPosted: Tue May 06, 2014 5:52 pm
Sounds like the head pipe joint is leaking.....use a Remflex at that joint.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 7 guests
