| How to build a mild 225 slant 6 ??? https://slantsix.org/forum/viewtopic.php?t=55294 |
| Author: | dodgedarren [ Wed May 07, 2014 12:40 pm ] |
| Post subject: | How to build a mild 225 slant 6 ??? |
Hello, My good friend Mark at Moto Guzzi Classics recommended that I join this sight. He said that there it lots of knowledgeable Mopar people who love to help complete ignorants like me. I bought a 1971 Dodge Dart 2 door with a 225ci slant 6. The engine is at the machine shop and I will be doing the assembly. I am staying with the stock intake a carb for now unless someone has a 2 barral set up they are looking to sell. Question: For a mild build that runs smooth but has a little more torque on the low end, what is recommended? 1. How much should I take off the head and block? .090 head only or .040 head .050 block? 2. What bore should I go with? 3. I've been recommend / need Erson Cam RV10? Any help or guidance would be recommended. Thank you, Darren [/img] |
| Author: | Joshie225 [ Wed May 07, 2014 12:49 pm ] |
http://www.slantsix.org/forum/viewforum.php?f=15 |
| Author: | Aggressive Ted [ Wed May 07, 2014 4:30 pm ] |
Look under Engine FAQ, Engine builds. Check out my build. |
| Author: | SlantSteve [ Wed May 07, 2014 6:59 pm ] |
This is only my personal opinion,but I'd be inclined to take roughly equal amounts off the head and block to get the required comp ratio... Others would perhaps say do the head and leave the block,dealers choice I say. If your cutting the block and head, I'd say go for a regrind cam,the reduced base circle on the cam from regrinding will help compensate for the deck/ head milling and make valve adjustment a little closer, plus you won't have any oil pump gear problems. I've read that some guys need custom length push rods with stock base circle cams and trimmed deck and heads. You guys have plenty of options of good grinds available,for a mild build I'd say something close to the comp 252 would be good,I think Ted got his regrind from Delta cams and its similar to the Comp grind. Even the stock 2bbl cam is a good improvement over the stock 1bbl cam from what I've read. I'm over in Australia so I can't really comment on availability of Erson grinds,but I believe you need to contact them and order one directly? But don't quote me on that! |
