| Oil shield/baffle for Offy cover? https://slantsix.org/forum/viewtopic.php?t=55327 |
| Author: | bcschief [ Sun May 11, 2014 1:51 pm ] |
Needs a PCV valve and the hose to the carb this will help with crankcase pressure. Brian |
| Author: | 65 dartman [ Sun May 11, 2014 2:02 pm ] |
Here you go - stovepipe added for a PCV ![]() and baffles added for each one: ![]() all TIG welded in |
| Author: | newpoppop [ Mon May 12, 2014 1:00 pm ] |
| Post subject: | lol. |
LOL. |
| Author: | JR [ Sat May 24, 2014 1:45 pm ] |
| Post subject: | Re: Oil shield/baffle for Offy cover? |
No nothing will fix the problem and you should immediately send me the cover for proper disposal.EDIT: Please remember to wipe the oil off before sending as I dont want to get my fingers dirty handling the item[/quote] Damn, I was afraid of that!!! I will box it up and get it shipped asap |
| Author: | '67 Dart 270 [ Sun May 25, 2014 6:54 pm ] |
| Post subject: | wow |
Those Stelling's are cool. I did like Dartman, cut a hole, fabricated a rear stack for PCV, then tig welded baffles into my offy. See: http://s785.photobucket.com/user/67dart ... f.jpg.html Brian |
| Author: | '67 Dart 270 [ Sun May 25, 2014 6:59 pm ] |
| Post subject: | Pvc |
BTW, I've done this twice. The one I showed in the pic only has a rear baffle, nothing in the front stand pipe (I can look down and see my rocker arms). I don't have any leakage oil problems. Perhaps you aren't getting enough crankcase ventilation? Make sure you do, it is very important. brian |
