It is currently Wed May 06, 2026 7:44 am
 Post subject: 727 ratios
PostPosted: Sat Apr 26, 2003 1:45 pm
Recently, I aquired a slant six 727 TF that came from an early '70's truck. Are the gear ratio's the same as the ratio's used in the 904 and automotive 727's?
PostPosted: Sat Apr 26, 2003 2:54 pm
727s OEM gear ratios were always 2.45, 1.45, 1.00, with OD applications .68.
Cecil
PostPosted: Sat Apr 26, 2003 10:04 pm
Thanks Cecil. I have alway heard that the truck trannys had a lower first gear. Guess not!
PostPosted: Sun Apr 27, 2003 9:26 am
There was a low 1st gear set available, from Mopar Performance, at one time. Don't know if it is still available, not cheap. Don't know if it was ever installed stock from the factory. Defer the Cecil on that.
