It is currently Thu May 21, 2026 12:21 pm
PostPosted: Tue May 20, 2014 2:02 pm
Anyone out there have a good defrost cable and that large spring clip that clips the defrost cable in place to that bracket off the heater box? The wagon is a 63 Dart with A/C and the controls moved to top-of-dash, so I need the longer defrost cable out of a '64 Dart.
My defrost cable is probably the stock '63 cable and it's too short to stretch to the bracket: whatever spring clip I had is long gone.
PostPosted: Wed May 21, 2014 7:52 am
I might have one if the'63 Valiant and Dart used the same cable. Are the Dart controls divorced from the dash like the Valiant's are?
PostPosted: Wed May 21, 2014 10:13 am
The controls were originally located in an under-dash control box, but my car has been converted to the '64 location.
If you have that spring clip though, I could still use it!
